Front spoiler suggestions - V8 conversion |
MM1 |
Sep 27 2022, 09:11 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I need a front spoiler to direct air into the radiator cut out of the front bumper on my 1974 914 V8 conversion (narrow body).
I far prefer the OEM front valance to any front spoiler but I definitely need some kind of air dam. Unfortunately at the moment budget is a big factor, so I was hoping to get a used LE front spoiler - but I haven’t seen one in quite a while so that seems unlikely. Can you please share any thoughts, suggestions and/or experiences regarding the American International Racing (AIR) version versus 914Rubber (the only ones I found online so far)? Years ago I read here how poorly all of the fiberglass versions fit . I bought a fiberglass version of the OEM style here last year and since it has tabs but no pre-drilled holes I am wondering how difficult it is to Mark and drill holes that will allow for the best possible alignment . For reference the cut out on my front bumper is 650 mm (25-5/8”). |
Robarabian |
Sep 27 2022, 09:58 PM
914 A Roo Group: Members Posts: 592 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California |
jcd914 |
Sep 27 2022, 10:51 PM
I bought a fiberglass version of the OEM style here last year and since it has tabs but no pre-drilled holes I am wondering how difficult it is to Mark and drill holes that will allow for the best possible alignment . I did this recently with an LE replica from 914rubber. Held the spoiler in place with blue painter tape (a lot) and then marked it, took it off to drill it and I think it fits ok. Jim |
Montreal914 |
Sep 28 2022, 01:13 AM
Senior Member Group: Members Posts: 1,560 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California |
...For reference the cut out on my front bumper is 650 mm (25-5/8”). Marcus, what bumper? (IMG:style_emoticons/default/poke.gif) Sounds like Rob has solved your problems all together! (IMG:style_emoticons/default/smile.gif) |
Steve |
Sep 28 2022, 06:28 AM
914 Guru Group: Members Posts: 5,589 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Check out Renegade hybrids
https://www.renegadehybrids.com/914/914valance.html They have several designed for v8 conversions. |
Front yard mechanic |
Sep 28 2022, 07:52 AM
Senior Member Group: Members Posts: 1,164 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Check out Renegade hybrids https://www.renegadehybrids.com/914/914valance.html They have several designed for v8 conversions. Just checked out their wall of shame (IMG:style_emoticons/default/barf.gif) |
Chris H. |
Sep 28 2022, 08:09 AM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Check out Renegade hybrids https://www.renegadehybrids.com/914/914valance.html They have several designed for v8 conversions. Just checked out their wall of shame (IMG:style_emoticons/default/barf.gif) Yeah those are pretty bad. It doesn't take much to get it wrong. Lot of sharp edges on those! I have the renegade valance and it fits great. Pushes a lot of air through for sure. |
MM1 |
Sep 28 2022, 01:35 PM
MM1 |
Sep 28 2022, 01:36 PM
...For reference the cut out on my front bumper is 650 mm (25-5/8”). Marcus, what bumper? (IMG:style_emoticons/default/poke.gif) Sounds like Rob has solved your problems all together! (IMG:style_emoticons/default/smile.gif) I know, right? |
MM1 |
Sep 28 2022, 01:38 PM
I spoke to someone at Renegade - off the record, I was told that the design is a bit off center.
tygaboy |
Sep 28 2022, 01:43 PM
914 Guru Group: Members Posts: 5,295 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
If you get a regular fiberglass GT front valance, it's easy enough to cut and widen the opening to exactly match your bumper. I did that to a friend's V8 conversion.
We ended up widening and lowering the opening to make it a bit deeper. And here's what I'm using on my car. Clearly, it's not yet bolted on. I don't know when I may get to it but I plan to pull a mold from this one and be able to reproduce it. Attached thumbnail(s) |
Montreal914 |
Sep 29 2022, 08:55 AM
If you get a regular fiberglass GT front valance, it's easy enough to cut and widen the opening to exactly match your bumper. I did that to a friend's V8 conversion. We ended up widening and lowering the opening to make it a bit deeper. And here's what I'm using on my car. Clearly, it's not yet bolted on. I don't know when I may get to it but I plan to pull a mold from this one and be able to reproduce it. Thank you for showing pictures of the result. Did it ended up being about the same height as an LE one? I am thinking about modifying an LE and creating an intake opening for cooler, but with the LE already having a reduced height in the center portion, I fear it will make that section too thin and will not look as good. I will be looking forward to seeing you making replicas of this valance! (IMG:style_emoticons/default/smilie_pokal.gif) |
tygaboy |
Sep 29 2022, 09:03 AM
@Montreal914 - Here's a pic of the car with the modded valance. Note that's a fiberglass bumper and I opened that up, too.
The angle makes it look like the openings don't align. They do! I don't know much about stock 914 parts so couldn't tell you how this compares with an LE air dam. Attached image(s) |
Montreal914 |
Sep 29 2022, 09:16 AM
I was referring to the valance you got on eBay you are showing in your picture. How does that one compares in height (whole valance not the opening for the cooler) to an LE valance since they share a similar design. My LE is stored in the rafters, but I would be interested in comparing heights.
Thanks! |
tygaboy |
Sep 29 2022, 10:59 AM
OK then - here's that one. Again, no idea what an LE measures.
Montreal914 |
Sep 29 2022, 01:20 PM
Thanks!
Pulled out my LE replica and measure closer to 4 3/4". Clearly your very hard to find valance is a good 3/4" taller with the nice cooler opening. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 19th May 2024 - 10:56 AM |
