Brake Light Switch, Adjustment? |
StarBear |
Sep 30 2022, 05:07 PM
Senior Member Group: Members Posts: 1,886 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
Today I noticed that my brake lights don't come on until the pedal is maybe 3/4 depressed, maybe more. It seems from the thread below and comment that maybe I just need to adjust the switch to be activated with less brake pedal travel? The switch is original.
Also, anything else in there I should be replacing so long as I have it opened up? Maybe even replacing the 50-year old switch? 74 1.8L Thanks! http://www.914world.com/bbs2/index.php?showtopic=338714 Post #9: "...The brake switch only makes contact and closes the circuit when it reaches the absolute end of stroke, which is set using the locknut/screw on the switch, I have mine adjusted so that the washer pulls away from the switch arm and actuates the lights just the tiniest bit before I start to feel any resistance from the brake pedal." |
Mikey914 |
Sep 30 2022, 09:56 PM
The rubber man Group: Members Posts: 12,669 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Look on the brake pedal. You’ll see the switch. Once you find it it will make a lot more sense.
Lo-Fi Version | Time is now: 19th May 2024 - 05:28 AM |
