Should I be concerned with this trailing arm? |
peteinjp |
Oct 2 2022, 06:30 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Not running huge tires but 2.7 rs engine and close gears- tires will likely be sticky 205's in the future but on 15x6's with 195's at the moment. Car weight- 970kg (2138lbs.)
Personally it looks a bit questionable but I'm new 914's. Could I use this for a while with plans to upgrade. Should I consider fully reinforcing both arms with this set up? Pete |
Lo-Fi Version | Time is now: 19th May 2024 - 12:34 PM |
