European Header Merge Collector, Where to find Replacement or Better to Modify |
motorvated |
Oct 3 2022, 04:50 PM
Member Group: Members Posts: 279 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
Lost the Merge Collector off of my European Racing Header exhaust system during an off-track "excursion" last weekend and after searching around the perimeter of the entire track, it could not be found. The piece is a slip-on 4-into-1 collector with 1.65" primaries and a 2.0" outlet. I still have the megaphone tail piece that remained attached to the car.
Considering the diameters of the header pipes and collector outlet, I'm wondering if I should do something a little different and less restrictive at this point, or just try to find a replacement for the missing piece. Any benefit if I switch to two 2-into-1 collectors and run the two 2.0 inch outlets to the back of the car. I could weld in a crossover between them if that would help balance the system. Any thoughts on what might work best? Thanks, Mike S. |
Craigers17 |
Oct 3 2022, 05:30 PM
Senior Member Group: Members Posts: 733 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
I don't know if they sell parts "a la carte", but these guys sell the header system. GLWT!
https://www.gt-racing.com/porsche-914-europ...art-914-4-158r/ |
brant |
Oct 3 2022, 06:04 PM
The creator (George) passed
But GT racing bought out the rights for production |
infraredcalvin |
Oct 3 2022, 07:25 PM
Distracted Member Group: Members Posts: 1,515 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California |
Burns stuff is purdy…
https://burnsstainless.com/products/4-into-1-base-collectors Also check with our own exhaust experts Ben or Marty…. @mb911 @Maltese Falcon |
Charles Freeborn |
Oct 4 2022, 01:52 PM
Member Group: Members Posts: 249 Joined: 21-May 14 From: United States Member No.: 17,377 Region Association: Pacific Northwest |
I bought a 4 to 1 collector from Summit. My headwrb Ant Euro, but close. Cost about 50 bucks as I recall. Does require some welding and fab for the bolt brackets. I can post pics when I’m home again in a few weeks.
motorvated |
Oct 5 2022, 09:29 AM
I bought a 4 to 1 collector from Summit. My headwrb Ant Euro, but close. Cost about 50 bucks as I recall. Does require some welding and fab for the bolt brackets. I can post pics when I’m home again in a few weeks. Thanks, I have been looking on Summit but haven't found a direct fit, but close. Still might go for two 2-into-1 collectors and two tailpipe extensions eith megaphones for better breathing. |
stownsen914 |
Oct 6 2022, 07:31 AM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Another option ... Cone Engineering makes about every configuration you can imagine. Does require assembly/fabrication.
https://www.coneeng.com/collector_components.html |
Charles Freeborn |
Oct 7 2022, 11:59 AM
I bought a 4 to 1 collector from Summit. My headwrb Ant Euro, but close. Cost about 50 bucks as I recall. Does require some welding and fab for the bolt brackets. I can post pics when I’m home again in a few weeks. Thanks, I have been looking on Summit but haven't found a direct fit, but close. Still might go for two 2-into-1 collectors and two tailpipe extensions eith megaphones for better breathing. The one I bought is made by Schoenfeld. My headers are 1.75 I.d. And the slip fit works well. They also make a 1-⅝ “ model. Quality isn’t superb but adequate for the task and price. |
motorvated |
Oct 7 2022, 05:55 PM
I bought a 4 to 1 collector from Summit. My headwrb Ant Euro, but close. Cost about 50 bucks as I recall. Does require some welding and fab for the bolt brackets. I can post pics when I’m home again in a few weeks. Thanks, I have been looking on Summit but haven't found a direct fit, but close. Still might go for two 2-into-1 collectors and two tailpipe extensions eith megaphones for better breathing. The one I bought is made by Schoenfeld. My headers are 1.75 I.d. And the slip fit works well. They also make a 1-⅝ “ model. Quality isn’t superb but adequate for the task and price. I can find Schoenfeld at Summit that has 1.625 inch primaries, but the smallest outlet I can find is 3 inch when I need 2". |
Charles Freeborn |
Oct 9 2022, 02:44 AM
I bought a 4 to 1 collector from Summit. My headwrb Ant Euro, but close. Cost about 50 bucks as I recall. Does require some welding and fab for the bolt brackets. I can post pics when I’m home again in a few weeks. Thanks, I have been looking on Summit but haven't found a direct fit, but close. Still might go for two 2-into-1 collectors and two tailpipe extensions eith megaphones for better breathing. The one I bought is made by Schoenfeld. My headers are 1.75 I.d. And the slip fit works well. They also make a 1-⅝ “ model. Quality isn’t superb but adequate for the task and price. I can find Schoenfeld at Summit that has 1.625 inch primaries, but the smallest outlet I can find is 3 inch when I need 2". Muffler shop can make you a reducer. |
stownsen914 |
Oct 9 2022, 10:04 AM
I have a European Racing header at home that I can measure. Pretty sure it's not 2" at then flange, maybe 2 1/4" or 2 1/2".
motorvated |
Oct 9 2022, 01:28 PM
stownsen914 |
Oct 9 2022, 05:11 PM
Happy to - I'll be back home in a couple days
Lo-Fi Version | Time is now: 15th May 2024 - 01:48 PM |
