Strut Insert Failed?, Firm No Vert Travel |
Costa05 |
Oct 16 2022, 06:23 PM
Member Group: Members Posts: 320 Joined: 27-October 16 From: Phoenix, Arizona Member No.: 20,535 Region Association: Southwest Region |
Replaced my tie rods today to help remove a bump steer wobble I get when hitting uneven pavement. Test drive was ok but still there. Noticed that I get zero vert movement when pushing down on the right front fender, whereas left front I get 1" to 2" of travel. In addition right side is 1" lower than left at rest. Is it the strut insert that failed? It does extend out when raising car to remove wheel though. Original setup on the car. 73 with late struts and calipers.
Oct 16 2022, 07:17 PM
They do fail after 50 years.
lesorubcheek |
Oct 16 2022, 07:45 PM
Member Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States |
I don't have too much experience with old strut inserts, but the few I've changed usually had zero resistance over a range and then they'd dampen for the remainder. None of the dozen or so I've changed ever just locked hard. Maybe they can, again, just never saw it personally. I'd almost guess the adjuster for your torsion bar backed out and bottomed out on that side.
Dan |
Costa05 |
Oct 16 2022, 11:08 PM
I don't have too much experience with old strut inserts, but the few I've changed usually had zero resistance over a range and then they'd dampen for the remainder. None of the dozen or so I've changed ever just locked hard. Maybe they can, again, just never saw it personally. I'd almost guess the adjuster for your torsion bar backed out and bottomed out on that side. Dan Dan you were right. I added about 3 full turns to the right side tortion bar adjuster. Rt side leveled out with left and now I have some strut & tortion bar travel to work with. Test drive was a big improvement. Thanks! Rich |
bdstone914 |
Oct 17 2022, 08:57 AM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I don't have too much experience with old strut inserts, but the few I've changed usually had zero resistance over a range and then they'd dampen for the remainder. None of the dozen or so I've changed ever just locked hard. Maybe they can, again, just never saw it personally. I'd almost guess the adjuster for your torsion bar backed out and bottomed out on that side. Dan Dan you were right. I added about 3 full turns to the right side tortion bar adjuster. Rt side leveled out with left and now I have some strut & tortion bar travel to work with. Test drive was a big improvement. Thanks! Rich Put some Blue Loctite on the adjuster screw irvit will back out again. Bruce |
Costa05 |
Oct 17 2022, 09:17 AM
I don't have too much experience with old strut inserts, but the few I've changed usually had zero resistance over a range and then they'd dampen for the remainder. None of the dozen or so I've changed ever just locked hard. Maybe they can, again, just never saw it personally. I'd almost guess the adjuster for your torsion bar backed out and bottomed out on that side. Dan Dan you were right. I added about 3 full turns to the right side tortion bar adjuster. Rt side leveled out with left and now I have some strut & tortion bar travel to work with. Test drive was a big improvement. Thanks! Rich Put some Blue Loctite on the adjuster screw irvit will back out again. Bruce Great advice Bruce. Interesting outcome is now that I have restored the control arm travel, I now have squeaking right front bushings. Next project on the list. |
bdstone914 |
Oct 17 2022, 11:12 AM
I don't have too much experience with old strut inserts, but the few I've changed usually had zero resistance over a range and then they'd dampen for the remainder. None of the dozen or so I've changed ever just locked hard. Maybe they can, again, just never saw it personally. I'd almost guess the adjuster for your torsion bar backed out and bottomed out on that side. Dan Dan you were right. I added about 3 full turns to the right side tortion bar adjuster. Rt side leveled out with left and now I have some strut & tortion bar travel to work with. Test drive was a big improvement. Thanks! Rich Put some Blue Loctite on the adjuster screw or it will back out again. Bruce Great advice Bruce. Interesting outcome is now that I have restored the control arm travel, I now have squeaking right front bushings. Next project on the list. The squeak may be the torsion bar rubbing on the housing. |
dr914@autoatlanta.com |
Oct 17 2022, 11:17 AM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
usually it is the red koni oil shocks that fail by freezing "up". no movement what so ever
Replaced my tie rods today to help remove a bump steer wobble I get when hitting uneven pavement. Test drive was ok but still there. Noticed that I get zero vert movement when pushing down on the right front fender, whereas left front I get 1" to 2" of travel. In addition right side is 1" lower than left at rest. Is it the strut insert that failed? It does extend out when raising car to remove wheel though. Original setup on the car. 73 with late struts and calipers. |
Lo-Fi Version | Time is now: 15th May 2024 - 12:19 PM |
