Fog Lights, Fog Lights on w/o head lights on. |
davenorcal |
Oct 29 2022, 06:53 PM
Newbie Group: Members Posts: 29 Joined: 5-June 21 From: Northern California Member No.: 25,605 Region Association: Northern California |
Can anyone direct me on where to look to find out how to modify the wiring (914/6) so I can have my fog lights on without having my headlights on. Thanks much!
914Sixer |
Oct 30 2022, 05:44 AM
J West kit. Seems there was info at Pelican 914 Forum how to do it.
Attached thumbnail(s) |
GregAmy |
Oct 30 2022, 06:30 AM
Advanced Member Group: Members Posts: 2,298 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
https://members.rennlist.com/demick/fogrewire.html
I did 1a, which occasionally resulted in walking away from the car with the parking lights on, and its resultant battery drainage. I resolved that with an annoying piezo buzzer wired, behind the dash, between |
davenorcal |
Oct 30 2022, 09:28 AM
Perfect…I’ll check out both of these suggestions. Thank you!
davenorcal |
Oct 30 2022, 05:40 PM
The J West option was looking good until the last line that states not for original 914/6, which is what I have.
ClayPerrine |
Nov 1 2022, 01:28 PM
Life's been good to me so far..... Group: Admin Posts: 15,462 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I am doing this from memory, so I may be wrong...
I don't remember the wire color, but one of the low beam fuses has two wires coming off of one side. This powers up the fog light relay. When you switch to high beams, the fog lights go off. If you move this wire to the ignition power fuse, the fog lights will come on anytime you have the key on. I will look later at a diagram. Hope that helps. Clay |
Ansbacher |
Nov 1 2022, 02:40 PM
Senior Member Group: Members Posts: 689 Joined: 4-July 14 From: Tampa Bay, Florida Member No.: 17,589 |
I found it easy to just to tap 12V from one of the wires up inside the driver side fender that feeds the parking lights. Your fogs will come on with the parking lights.
Another cool thing you can do while your under the fender, is to wire your side marker light to blink with the blinkers. Ansbacher |
mgphoto |
Nov 1 2022, 03:39 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I am doing this from memory, so I may be wrong... I don't remember the wire color, but one of the low beam fuses has two wires coming off of one side. This powers up the fog light relay. When you switch to high beams, the fog lights go off. If you move this wire to the ignition power fuse, the fog lights will come on anytime you have the key on. I will look later at a diagram. Hope that helps. Clay Clay is right, I did this using a tech tip in Panorama, it probably made it in a volume of UpFixin. |
Lo-Fi Version | Time is now: 14th May 2024 - 07:47 PM |
