QUOTE(ClayPerrine @ Nov 1 2022, 12:28 PM)
I am doing this from memory, so I may be wrong...
I don't remember the wire color, but one of the low beam fuses has two wires coming off of one side. This powers up the fog light relay. When you switch to high beams, the fog lights go off. If you move this wire to the ignition power fuse, the fog lights will come on anytime you have the key on.
I will look later at a diagram.
Hope that helps.
Clay
Clay is right, I did this using a tech tip in Panorama, it probably made it in a volume of UpFixin.
