Steering Rack Cover, Got those bolts off ! |
jim_hoyland |
Oct 30 2022, 03:50 PM
Get that VIN ? Group: Members Posts: 9,287 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Update:
Success ! Raised the front end yesterday and sprayed PB Blaster on each bolt multiple times. Tapped the bolt heads 15-20x between applications. This morning the bolt heads turned and I was on the road to an unrelated project. The 4 bolts that hold the cover are impossible to turn;plus the two front ones require an angled socket ; Need suggestions......... BFH on the 13mm wrench wouldn't budge the bolt either. |
Craigers17 |
Oct 30 2022, 04:01 PM
Senior Member Group: Members Posts: 733 Joined: 5-August 17 From: Rome, GA Member No.: 21,317 Region Association: South East States |
Soak them with some PB Blaster and try a little later. If that doesn't work, buy one of these....it might help out with the angle as well. You can find a relatively cheap one at Harbor Freight.
jim_hoyland |
Oct 30 2022, 04:51 PM
Thanks, will do. I have that too too. The corners of the bolt heads may be getting worn down too (IMG:style_emoticons/default/sad.gif)
Superhawk996 |
Oct 30 2022, 06:07 PM
914 Guru Group: Members Posts: 5,812 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Thanks, will do. I have that too too. The corners of the bolt heads may be getting worn down too (IMG:style_emoticons/default/sad.gif) Use only six point sockets. I personally never use a 12 point socket unless I’m forced to working on an old 4 sided nut or I know the fastener doesn’t need much torque. 12 point sockets are junk for trying to get any thing unstuck (don’t care what brand). I’d use lots of heat before you resort to the breaker bar. I’ve seen far too many of those steering rack fasteners sheared off. When I bought my rust bucket, there was already one of the fasteners sheared off, with an EZ out also broken off in it. Replacement via welding was the fix. Fortunately - I was replacing all the floor pan anyway. Trust me - you don’t want to shear one off. |
jim_hoyland |
Oct 30 2022, 06:50 PM
Thanks. I check the sockets, I must have some 6 pts. Can’t use heat, there’s soft parts near each bolt. Gonna state the PB Blaster tomorrow….
Oct 30 2022, 08:42 PM
914-6 GT in waiting Group: Members Posts: 19,270 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
6 point impact sockets and a rattle gun. The impact of the tools hammers breaks loose fasteners without breaking the fastener.
jim_hoyland |
Oct 30 2022, 08:50 PM
6 point impact sockets and a rattle gun. The impact of the tools hammers breaks loose fasteners without breaking the fastener. I’ll try that….. (IMG:style_emoticons/default/smile.gif) |
Ishley |
Oct 30 2022, 10:57 PM
Member Group: Members Posts: 96 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
It's critical that you try not to break those bolts. You'll go into a whole new level of frustration. I broke one of mine... and it took days to get it out... and then only with a welder and some tricky effort.
I would not get a bigger rachet... but 6 point socket is a good idea. You'll make it easier to break. Soak with lube... for several days if you can. I would use a torch and some heat. Get as much heat on there as you can... even if its only the head of the bolt... firm but not overly aggressive on the bolt... try to move it both ways.... if it won't move, more lube and wait. I good crack with a hammer too. Try heat again... and repeat until you get it to budge. If the snap off up inside the mount you have a big mess on your hands. Don't forget anti seize when you but it back together. |
bob164 |
Oct 30 2022, 11:27 PM
Member Group: Members Posts: 96 Joined: 10-February 18 From: SoCal Member No.: 21,877 Region Association: Southern California |
Jim,
l can come over some time this week with my impact gun and impact 6 point sockets. Give me a call. Bob |
second wind |
Oct 31 2022, 01:31 AM
Senior Member Group: Members Posts: 851 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hello Jim...heat is the answer....just be careful not to start a fire or melt anything nearby.... I am talking propane torch right on the item and then carefully attempt to loosen....it worked on my lower seat belts bolts which were brown with rust...so glad they finally came out....all the best and be gentle...let the heat do the work...plus I would put some juice on them for a couple of days....two pronged attack...you got this !!
All the best, gg |
jim_hoyland |
Oct 31 2022, 05:56 AM
Jim, l can come over some time this week with my impact gun and impact 6 point sockets. Give me a call. Bob Thanks Bob,I'll call today. (IMG:style_emoticons/default/smile.gif) |
Superhawk996 |
Oct 31 2022, 07:52 AM
Can’t use heat, there’s soft parts near each bolt. Steering rack cover seals are easily replaced. I’d sacrifice seals (and paint) to heat before I’d risk shearing a bolt head off. If you do decide to go the impact gun route - start with the lowest setting. Impact guns will shear bolts just as well as a breaker bar if used improperly. Fully agree though that the impact gun cyclic torque is beneficial in loosening fasteners. Didn’t realize you have that available as an option. Intermix penetrating oil with some impact use and even some more heat - back and forth before ratcheting up the impact gun torque level. Wishing you good luck - (IMG:style_emoticons/default/beerchug.gif) |
Ishley |
Oct 31 2022, 10:03 AM
I don’t think an impact gun is the answer. These bolts seize from rust. I broke mine thinking bigger was better. On the second bolt I used heat and a regular 3/8 ratchet. Go slow lots of heat. I have one of these oxygen/mapp gas torches… I get everything really hot. Try tighten and loosen. Hit it hard on the head with a hammer to help shock it
Loose. More heat and patience. |
windforfun |
Oct 31 2022, 05:05 PM
Senior Member Group: Members Posts: 1,780 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Too bad it’s under the gas tank.
(IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) |
Superhawk996 |
Oct 31 2022, 05:41 PM
Too bad it’s under the gas tank. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) Hot work permit needs to be filled out - I’ll sign it for ya’ (IMG:style_emoticons/default/happy11.gif) Attached thumbnail(s) |
jim_hoyland |
Oct 31 2022, 06:11 PM
Too bad it’s under the gas tank. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/dry.gif) I was just think about that …..hmmmm |
Oct 31 2022, 06:50 PM
Couple of layers of sheet metal between the bolts and the tank. Should not be a problem.
For any stuff you're worried about melting, stick some sheet metal between where the flame is and where the potentially-melty thing is. If you're really worried, you can use a spray bottle of water to keep the sheet metal cool or spray directly on the potentially-melty thing. Heat is your friend. --DD |
Ishley |
Oct 31 2022, 07:20 PM
If you break those bolts you’ll have wished you would’ve pulled the tank. On the one I broke I was able to finally weld enough of a nub to grab it with vise grips and work it out. I also had the pan off and was able to add more heat higher up.
Broken bolts in the wrong places are a real nightmare . I’ve had several and every time I wished I’d of slowed down and worked out a better plan. |
Superhawk996 |
Oct 31 2022, 09:39 PM
Broken bolts in the wrong places are a real nightmare . I’ve had several and every time I wished I’d of slowed down and worked out a better plan. Truth (IMG:style_emoticons/default/aktion035.gif) |
lesorubcheek |
Nov 1 2022, 11:29 AM
Member Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States |
If you break those bolts you’ll have wished you would’ve pulled the tank. On the one I broke I was able to finally weld enough of a nub to grab it with vise grips and work it out. I also had the pan off and was able to add more heat higher up. Broken bolts in the wrong places are a real nightmare . I’ve had several and every time I wished I’d of slowed down and worked out a better plan. Wise words Ishley. About the only thing more painful than a broken screw/bolt is a broken extractor in a broken screw/bolt. Heat, impact (not impact wrench), penetrating oil, then repeat until it'll come loose without a crowbar. Dan |
Lo-Fi Version | Time is now: 14th May 2024 - 07:02 AM |
