Steering Rack Cover, Got those bolts off ! |
930cabman |
Nov 1 2022, 12:49 PM
Advanced Member Group: Members Posts: 3,109 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Are these blind? if they penetrate into the area below the fuel tank, I would pull the tank, allow your favorite penetrant to soak in for a day or so, then go at it with a bit of heat and impact gun.
jim_hoyland |
Nov 2 2022, 01:46 PM
Get that VIN ? Group: Members Posts: 9,312 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Mission accomplished (IMG:style_emoticons/default/smile.gif) See update in post 1
Superhawk996 |
Nov 2 2022, 02:28 PM
914 Guru Group: Members Posts: 5,869 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
(IMG:style_emoticons/default/smilie_pokal.gif) Good - no drama is a great thing!
Ishley |
Nov 2 2022, 05:34 PM
Member Group: Members Posts: 101 Joined: 4-October 21 From: Clarendon Hills Il Member No.: 25,957 Region Association: Upper MidWest |
That’s a relief! Congrats!
jim_hoyland |
Nov 2 2022, 07:48 PM
Now to get back to the original reason I needed to remove the steering rack cover; I’m going to make a small opening, either on the bottom or on the side, for resetting the MC switch. I had read about this on a thread. After bleeding the brakes, my MC switch goes off and I get the blinking red light. A hole directly under the switch will allow me to reach up with my finger to reset.
Not a big deal. (IMG:style_emoticons/default/smile.gif) |
jim_hoyland |
Nov 2 2022, 07:49 PM
Not a big deal. (IMG:style_emoticons/default/smile.gif) Attached thumbnail(s) |
bkrantz |
Nov 2 2022, 08:07 PM
914 Guru Group: Members Posts: 7,778 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
You could replace the switch (maybe it sticks). The switch can be removed from the MC without leaking brake fluid.
jim_hoyland |
Nov 2 2022, 08:31 PM
You could replace the switch (maybe it sticks). The switch can be removed from the MC without leaking brake fluid. Never knew that…. (IMG:style_emoticons/default/smile.gif) |
Krieger |
Nov 2 2022, 11:00 PM
Advanced Member Group: Members Posts: 4,721 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I can reset the switch with my car on the ground and the steering wheel at full right lock.
Nov 3 2022, 10:18 PM
You can see the button in the photo. Just reach in from the side, from the angle the photo was taken from. Easy-peasy!
--DD |
Lo-Fi Version | Time is now: 28th May 2024 - 04:42 PM |
