Removing CV Joint from Stub axle, Trying to do it on the car |
eyecolor |
Oct 30 2022, 03:59 PM
Eyecolor Group: Members Posts: 80 Joined: 15-August 08 From: Wilmington,DE Member No.: 9,425 Region Association: None |
I have disconnected the CV joint from the transmission and have the bare minimum left to remove from the splined end.. I have removed the C clip!!
Any trick to getting it to budge? The angle makes it difficult to pull with any real force. I am afraid any type of 3 jaw puller will bend something it should not. I did let it soak with lubricant . I could get away with re-inserting the ball bearings but have found that after 3 of them gravity takes over. Open to any suggestions. Thanks George \Wilmington DE |
rgalla9146 |
Oct 30 2022, 06:51 PM
Advanced Member Group: Members Posts: 4,552 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Do you have the tools to remove the 32mm castle nut at the wheel end ? Then remove the drive shaft assembly and reassemble the CV under better circumstances. |
rgalla9146 |
Oct 30 2022, 06:54 PM
DBL
bkrantz |
Oct 30 2022, 07:15 PM
914 Guru Group: Members Posts: 7,761 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
914e |
Oct 31 2022, 12:23 AM
Member Group: Members Posts: 496 Joined: 21-February 20 From: Arizona Member No.: 23,951 Region Association: Southwest Region |
A brass drift punch might work. You need to use one to get the C clip back seated anyway when you put it back together.
930cabman |
Oct 31 2022, 05:36 AM
Advanced Member Group: Members Posts: 3,055 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Do you have the tools to remove the 32mm castle nut at the wheel end ? Then remove the drive shaft assembly and reassemble the CV under better circumstances. (IMG:style_emoticons/default/agree.gif) Yes, the assembly should really be on the bench for a proper repair. |
iankarr |
Oct 31 2022, 09:07 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
Check this video at 1:14 for removal. You basically use the joint like a slide hammer, but it reallly needs to be on the bench for leverage.
https://youtu.be/F-5Xpug52Qw |
eyecolor |
Oct 31 2022, 11:58 AM
Do you have the tools to remove the 32mm castle nut at the wheel end ? Then remove the drive shaft assembly and reassemble the CV under better circumstances. You all are correct, I'll get the sub axles off and repair or replace properly many thanks George Wilmington, DE |
930cabman |
Oct 31 2022, 01:41 PM
I have disconnected the CV joint from the transmission and have the bare minimum left to remove from the splined end.. I have removed the C clip!! Any trick to getting it to budge? The angle makes it difficult to pull with any real force. I am afraid any type of 3 jaw puller will bend something it should not. I did let it soak with lubricant . I could get away with re-inserting the ball bearings but have found that after 3 of them gravity takes over. Open to any suggestions. Thanks George \Wilmington DE Has the joint failed? I assume so, but let us know the symptom(s) |
Lo-Fi Version | Time is now: 13th May 2024 - 11:01 PM |
