I have disconnected the CV joint from the transmission and have the bare minimum left to remove from the splined end.. I have removed the C clip!!
Any trick to getting it to budge? The angle makes it difficult to pull with any real force.
I am afraid any type of 3 jaw puller will bend something it should not.
I did let it soak with lubricant .
I could get away with re-inserting the ball bearings but have found that after 3 of them gravity takes over.
Open to any suggestions. Thanks
George
\Wilmington DE
