Put a 2.7 6 into a 72 Bay Window Bus?, Porsche content. Don't judge me! |
VaccaRabite |
Nov 3 2022, 12:31 PM
En Garde! Group: Admin Posts: 13,444 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, Lets say you had a 2.7L 6 with complete and intact CIS, good compression, taken out of a running car that wanted to go electric.
And lets say you had a Bay Window Westy. And, for the sake of argument - what do you think it would take to put them together. I've got the 915 and the engine and a bus that's about 70% through its restoration. Current plan is to get the bus running on its existing 1.7 first. Then add the engine to the bus transmission and drive it like that. And eventually add the 915 into the mix which may or may not require a bunch of changes. I know that this is a thing that has been done. Anyone done it? For the first stage - I'd need an oil tank (maybe - may have one), and would need tins. A different flywheel and maybe a different clutch - may be able to take these off the bus. I'll need exhaust. Heat isn't a concern - I'm using a diesel heater for heat so I am not worried about heat exchangers. I suppose another option might be to put it into a dune buggy... but no. The bus will like it a good bit more. Zach |
gandalf_025 |
Mar 16 2023, 01:23 PM
Senior Member Group: Members Posts: 1,453 Joined: 25-June 09 From: North Shore, Massachusetts Member No.: 10,509 Region Association: North East States |
There were a couple of companies that had kits to put a V8 in the back seat
area of later Corvairs. You could buy the entire kit or any parts you wanted. The weak link was the input shaft that was specially made to enter the transmission from the wrong end. The transaxle was mounted in the stock position and turned backwards. people usually had trouble getting the run out of the input shaft low enough that it wouldn't self destruct in time. Also the reason Posi Corvair transaxles were in such high demand. There was also a GM Engineer that made a kit to put an entire Toronado drivetrain mid engine in a corvair. That kit allowed the use of the rear seats too. It was pretty bullet proof because the engine transmission were built to work together. It was an automatic though.. The guy I knew had an early Corvair... 1963 and he hung the engine out the back after figuring out a bell housing and turning the engine backwards. It handled terribly and was a handful to drive.. But it did stand up easy.. |
Lo-Fi Version | Time is now: 20th May 2024 - 03:00 AM |
