Put a 2.7 6 into a 72 Bay Window Bus?, Porsche content. Don't judge me! |
VaccaRabite |
Nov 3 2022, 12:31 PM
En Garde! Group: Admin Posts: 13,441 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, Lets say you had a 2.7L 6 with complete and intact CIS, good compression, taken out of a running car that wanted to go electric.
And lets say you had a Bay Window Westy. And, for the sake of argument - what do you think it would take to put them together. I've got the 915 and the engine and a bus that's about 70% through its restoration. Current plan is to get the bus running on its existing 1.7 first. Then add the engine to the bus transmission and drive it like that. And eventually add the 915 into the mix which may or may not require a bunch of changes. I know that this is a thing that has been done. Anyone done it? For the first stage - I'd need an oil tank (maybe - may have one), and would need tins. A different flywheel and maybe a different clutch - may be able to take these off the bus. I'll need exhaust. Heat isn't a concern - I'm using a diesel heater for heat so I am not worried about heat exchangers. I suppose another option might be to put it into a dune buggy... but no. The bus will like it a good bit more. Zach |
GregAmy |
Nov 11 2022, 04:00 PM
Advanced Member Group: Members Posts: 2,290 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Ever heard of the Porsche T3 B32? Me neither. Seven built for support Porsche's 959 Dakar Rally efforts.
https://www.autoblog.com/2008/04/15/did-you...agon-based-b32/ https://www.autoevolution.com/news/based-on...che-201540.html |
JamesM |
Nov 11 2022, 05:05 PM
Senior Member Group: Members Posts: 1,895 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Ever heard of the Porsche T3 B32? Me neither. Seven built for support Porsche's 959 Dakar Rally efforts. https://www.autoblog.com/2008/04/15/did-you...agon-based-b32/ https://www.autoevolution.com/news/based-on...che-201540.html If we are talking Vanagons, there was also the VW/Oettinger 3.2 flat 6 WBX motor. Basically a 2.1 WBX with 2 extra cylinders |
Lo-Fi Version | Time is now: 9th May 2024 - 09:24 AM |
