Put a 2.7 6 into a 72 Bay Window Bus?, Porsche content. Don't judge me! |
VaccaRabite |
Nov 3 2022, 12:31 PM
En Garde! Group: Admin Posts: 13,441 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, Lets say you had a 2.7L 6 with complete and intact CIS, good compression, taken out of a running car that wanted to go electric.
And lets say you had a Bay Window Westy. And, for the sake of argument - what do you think it would take to put them together. I've got the 915 and the engine and a bus that's about 70% through its restoration. Current plan is to get the bus running on its existing 1.7 first. Then add the engine to the bus transmission and drive it like that. And eventually add the 915 into the mix which may or may not require a bunch of changes. I know that this is a thing that has been done. Anyone done it? For the first stage - I'd need an oil tank (maybe - may have one), and would need tins. A different flywheel and maybe a different clutch - may be able to take these off the bus. I'll need exhaust. Heat isn't a concern - I'm using a diesel heater for heat so I am not worried about heat exchangers. I suppose another option might be to put it into a dune buggy... but no. The bus will like it a good bit more. Zach |
JamesM |
Nov 3 2022, 05:11 PM
Senior Member Group: Members Posts: 1,895 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Ah! So you are the one that bought that motor. Probably did me a favor, if it sat around much longer it might have wound up in my 914.
(IMG:style_emoticons/default/aktion035.gif) So, Lets say you had a 2.7L 6 with complete and intact CIS, good compression, taken out of a running car that wanted to go electric. And lets say you had a Bay Window Westy. And, for the sake of argument - what do you think it would take to put them together. I've got the 915 and the engine and a bus that's about 70% through its restoration. Current plan is to get the bus running on its existing 1.7 first. Then add the engine to the bus transmission and drive it like that. And eventually add the 915 into the mix which may or may not require a bunch of changes. I know that this is a thing that has been done. Anyone done it? For the first stage - I'd need an oil tank (maybe - may have one), and would need tins. A different flywheel and maybe a different clutch - may be able to take these off the bus. I'll need exhaust. Heat isn't a concern - I'm using a diesel heater for heat so I am not worried about heat exchangers. I suppose another option might be to put it into a dune buggy... but no. The bus will like it a good bit more. Zach |
VaccaRabite |
Nov 7 2022, 10:30 AM
Ah! So you are the one that bought that motor. Probably did me a favor, if it sat around much longer it might have wound up in my 914. (IMG:style_emoticons/default/aktion035.gif) I could not turn it down. Though it had put the build of my bus on its nose somewhat. Zach |
JamesM |
Nov 11 2022, 05:22 PM
Ah! So you are the one that bought that motor. Probably did me a favor, if it sat around much longer it might have wound up in my 914. (IMG:style_emoticons/default/aktion035.gif) I could not turn it down. Though it had put the build of my bus on its nose somewhat. Zach I was on the fence, but in no hurry to dive into something like that atm with all the other projects I have going on. The car it would have gone in is currently cut to bits at PMB getting rust repair done AND I just bought a new set of Tangerine headers for it that would never get installed if I change direction on the motor. Plus with the current motor being ~130-140ish hp, not sure if I would have felt it was all worth it in the end only gaining ~30-40hp as it sits. The idea of going though a motor that clean to upgrade it almost seemed wasteful... I mean that thing looked almost brand new. Maybe someday, 2.7 is my motor of choice for a 914. Glad it found a good home. |
Lo-Fi Version | Time is now: 8th May 2024 - 11:01 PM |
