Put a 2.7 6 into a 72 Bay Window Bus?, Porsche content. Don't judge me! |
VaccaRabite |
Nov 3 2022, 12:31 PM
En Garde! Group: Admin Posts: 13,441 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, Lets say you had a 2.7L 6 with complete and intact CIS, good compression, taken out of a running car that wanted to go electric.
And lets say you had a Bay Window Westy. And, for the sake of argument - what do you think it would take to put them together. I've got the 915 and the engine and a bus that's about 70% through its restoration. Current plan is to get the bus running on its existing 1.7 first. Then add the engine to the bus transmission and drive it like that. And eventually add the 915 into the mix which may or may not require a bunch of changes. I know that this is a thing that has been done. Anyone done it? For the first stage - I'd need an oil tank (maybe - may have one), and would need tins. A different flywheel and maybe a different clutch - may be able to take these off the bus. I'll need exhaust. Heat isn't a concern - I'm using a diesel heater for heat so I am not worried about heat exchangers. I suppose another option might be to put it into a dune buggy... but no. The bus will like it a good bit more. Zach |
Maltese Falcon |
Nov 12 2022, 12:28 PM
Advanced Member Group: Members Posts: 4,641 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
@mepstein Found an MSDS Vanagon ('80-92) 3.2L kit pic: 4wd/Syncro and 2wd d-i-y kits were offered.
I shipped the last kit off in '01 to a client in BC,Canada. Never mfg the earlier bus kits (not intererchangeable)...but this pic illustrates the major components made to fit the Vanagon platform. Not in pic; KEP clutch disc, flywheel, optional components ; P/S kit, Fr oil cooler + T'stat kit, 2 or 4 tip muffler styles, front brush guard, oil tank rock shield, front winch (Ramsey) mount plate. Very clean install and No high spots in the rear cargo/cushion area. |
Lo-Fi Version | Time is now: 8th May 2024 - 09:27 PM |
