Put a 2.7 6 into a 72 Bay Window Bus?, Porsche content. Don't judge me! |
VaccaRabite |
Nov 3 2022, 12:31 PM
En Garde! Group: Admin Posts: 13,441 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, Lets say you had a 2.7L 6 with complete and intact CIS, good compression, taken out of a running car that wanted to go electric.
And lets say you had a Bay Window Westy. And, for the sake of argument - what do you think it would take to put them together. I've got the 915 and the engine and a bus that's about 70% through its restoration. Current plan is to get the bus running on its existing 1.7 first. Then add the engine to the bus transmission and drive it like that. And eventually add the 915 into the mix which may or may not require a bunch of changes. I know that this is a thing that has been done. Anyone done it? For the first stage - I'd need an oil tank (maybe - may have one), and would need tins. A different flywheel and maybe a different clutch - may be able to take these off the bus. I'll need exhaust. Heat isn't a concern - I'm using a diesel heater for heat so I am not worried about heat exchangers. I suppose another option might be to put it into a dune buggy... but no. The bus will like it a good bit more. Zach |
Bartlett 914 |
Mar 16 2023, 03:49 PM
Advanced Member Group: Members Posts: 2,215 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I have a 91 Westy with a Suby 2.5. The power is great but not too much. Gearing is great in the city but I need a higher gear, 4K at 70mph. This is a water cooled bus. A suby is not a great fit for the older bus. I think this would make a great conversion. With the lower HP motor, these vans had trouble getting out of their own way. Maybe the 6 is overkill but I am sure you will love it. I hope you keep posting your conversion process here!
Maltese Falcon |
Mar 17 2023, 09:46 PM
Advanced Member Group: Members Posts: 4,641 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
I have a 91 Westy with a Suby 2.5. The power is great but not too much. Gearing is great in the city but I need a higher gear, 4K at 70mph. This is a water cooled bus. A suby is not a great fit for the older bus. I think this would make a great conversion. With the lower HP motor, these vans had trouble getting out of their own way. Maybe the 6 is overkill but I am sure you will love it. I hope you keep posting your conversion process here! When I was rolling down the highway in the Carrera powered 1986 Syncro, I had the 4th gear changed out to the Aussie (higher) ratio. Also had the 4wd transaxle rebuilt + blueprinted by a Baja-off road shop; as the stock box kept eating itself up. Somehow you should be able to source the higher 4th gear (syncro 4wd), I would think that the 2wd gear would be available somewhere. (IMG:style_emoticons/default/marty914.jpg) |
Lo-Fi Version | Time is now: 9th May 2024 - 12:03 PM |
