Put a 2.7 6 into a 72 Bay Window Bus?, Porsche content. Don't judge me! |
VaccaRabite |
Nov 3 2022, 12:31 PM
En Garde! Group: Admin Posts: 13,441 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, Lets say you had a 2.7L 6 with complete and intact CIS, good compression, taken out of a running car that wanted to go electric.
And lets say you had a Bay Window Westy. And, for the sake of argument - what do you think it would take to put them together. I've got the 915 and the engine and a bus that's about 70% through its restoration. Current plan is to get the bus running on its existing 1.7 first. Then add the engine to the bus transmission and drive it like that. And eventually add the 915 into the mix which may or may not require a bunch of changes. I know that this is a thing that has been done. Anyone done it? For the first stage - I'd need an oil tank (maybe - may have one), and would need tins. A different flywheel and maybe a different clutch - may be able to take these off the bus. I'll need exhaust. Heat isn't a concern - I'm using a diesel heater for heat so I am not worried about heat exchangers. I suppose another option might be to put it into a dune buggy... but no. The bus will like it a good bit more. Zach |
VaccaRabite |
May 10 2023, 07:59 PM
I did some measurements the other day.
The engine bay is 14 inches tall. The 2.7 with CIS is 18 inches tall from the top of the engine mount bar to the top of the highest point. So if I want to keep CIS I need to mount the engine lower in the bus and rig up a skid plate or something to protect it since it will now be the lowest part of the bus save the wheels. Or my measurements are wrong because I'm a total noob to 6 engines and I have no idea how they work or mount. @Maltese Falcon With you conversions back in the day... Was service to the engine a "drop the engine to change a spark-plug" kinda thing? Did the engines need to be lower in the engine bay to fit? I know if I went carbs or some other fuel injection I would loose several inches of height that the CIS currently has. And I'm sure Eric would be happy to sell me a plug and play injection setup when I get to that point if I don't want to use PMOs and can't get the stock CIS to work right. Thanks! Zach |
Lo-Fi Version | Time is now: 9th May 2024 - 01:09 AM |
