speedo cable, trying to install but seems long |
Type 47 |
Nov 8 2022, 07:12 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
bdstone914 |
Nov 8 2022, 08:15 PM
bdstone914 Group: Members Posts: 4,520 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Sounds about right. I route them above the axle secured to the top stud of the trans cover plate with a 1/2" loop clamp.
bkrantz |
Nov 8 2022, 08:23 PM
914 Guru Group: Members Posts: 7,761 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I actually wish mine was a bit longer. By the time it routes from the gauge to the front firewall, down into the tunnel, and then through the engine compartment, you will need every foot.
Type 47 |
Nov 9 2022, 09:34 AM
OK, great.
Thanks guys |
dr914@autoatlanta.com |
Nov 9 2022, 11:41 AM
914 Guru Group: Members Posts: 7,853 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
certainly IS the routing that makes the cable have to be longer than one would think
Retroracer |
Nov 9 2022, 12:32 PM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
I actually wish mine was a bit longer. By the time it routes from the gauge to the front firewall, down into the tunnel, and then through the engine compartment, you will need every foot. (IMG:style_emoticons/default/agree.gif) you think it looks long now? wait until your're wrestling it into place under the dash.... Situation normal. - Tony |
ClayPerrine |
Nov 10 2022, 09:08 AM
Life's been good to me so far..... Group: Admin Posts: 15,459 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Before you push it into the tunnel, wrap some electrical tape just under the threaded collar on the end that attaches to the speedometer so the collar can't slide down the cable. Otherwise the collar will end up getting caught on something inside the tunnel and it won't be there to hook to the speedo.
Good Luck! Clay |
Lo-Fi Version | Time is now: 13th May 2024 - 09:31 PM |
