Sounds about right. I route them above the axle secured to the top stud of the trans cover plate with a 1/2" loop clamp.
bkrantz
Nov 8 2022, 08:23 PM
I actually wish mine was a bit longer. By the time it routes from the gauge to the front firewall, down into the tunnel, and then through the engine compartment, you will need every foot.
Type 47
Nov 9 2022, 09:34 AM
OK, great.
Thanks guys
dr914@autoatlanta.com
Nov 9 2022, 11:41 AM
certainly IS the routing that makes the cable have to be longer than one would think
Retroracer
Nov 9 2022, 12:32 PM
QUOTE(bkrantz @ Nov 8 2022, 07:23 PM)
you think it looks long now? wait until your're wrestling it into place under the dash....
Situation normal.
- Tony
ClayPerrine
Nov 10 2022, 09:08 AM
Before you push it into the tunnel, wrap some electrical tape just under the threaded collar on the end that attaches to the speedometer so the collar can't slide down the cable. Otherwise the collar will end up getting caught on something inside the tunnel and it won't be there to hook to the speedo.
Good Luck! Clay
