WTB early seat rails for both sides |
Bagpype |
Nov 9 2022, 10:45 AM
Newbie Group: Members Posts: 46 Joined: 9-July 15 From: Atlanta, ga Member No.: 18,936 Region Association: None |
I don’t have the seat rails in my 1970 914. I am looking for a good set of rails for both the driver and passenger side. Anyone have any laying around they would like to sell?
914werke |
Nov 9 2022, 11:15 AM
"I got blisters on me fingers" Group: Members Posts: 10,087 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
While there is a "early" style seat slider/tilt base, to my knowledge there is no passenger version since the 70 had a fixed passenger seat OE.
If your car has had a movable Passenger seat installed & you want them to match L&R you probably want the late units. BTW I have the both available HERE |
Bagpype |
Nov 10 2022, 07:08 AM
While there is a "early" style seat slider/tilt base, to my knowledge there is no passenger version since the 70 had a fixed passenger seat OE. If your car has had a movable Passenger seat installed & you want them to match L&R you probably want the late units. BTW I have the both available HERE You rock! I actually found the drivers side but am having trouble finding the passenger side. |
Nov 10 2022, 08:08 AM
914-6 GT in waiting Group: Members Posts: 19,284 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
While there is a "early" style seat slider/tilt base, to my knowledge there is no passenger version since the 70 had a fixed passenger seat OE. If your car has had a movable Passenger seat installed & you want them to match L&R you probably want the late units. BTW I have the both available HERE You rock! I actually found the drivers side but am having trouble finding the passenger side. Passenger side seat bottom attaches directly to the floor. Fits over the studs mounted to the floor and is held in with some nuts and washers. No rails. As simple as can be. |
Bagpype |
Nov 10 2022, 02:12 PM
While there is a "early" style seat slider/tilt base, to my knowledge there is no passenger version since the 70 had a fixed passenger seat OE. If your car has had a movable Passenger seat installed & you want them to match L&R you probably want the late units. BTW I have the both available HERE You rock! I actually found the drivers side but am having trouble finding the passenger side. Passenger side seat bottom attaches directly to the floor. Fits over the studs mounted to the floor and is held in with some nuts and washers. No rails. As simple as can be. Thank you for this information. My floors are new so I’ll need to weld in some studs. |
Lo-Fi Version | Time is now: 24th May 2024 - 05:08 AM |
