Shift rod boot extension- Tangerine bushing. |
peteinjp |
Nov 13 2022, 06:20 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
My car has the tangerine bushing installed and while it does have a groove for the rubber boot in my case (may be related to the shift rod??) the boot just would not stay on when going into R,2, or 4. I measured the O.D. and found it conveniently to be 2.25" and ordered this 2.25 to 2.5"I.D. exhaust adapter:
(IMG:http://www.914world.com/bbs2/uploads_offsite/m.media-amazon.com-25723-1668342024.1.jpg) A little chopping, belt sanding and then some hammer work on a simple buck yielded this: Installed (slip fit but may do use some sealant to keep water out:) In action: Just thowing this out there in case others have the same problem- which I admit is unlikely but anyway.... Best! Pete |
Cairo94507 |
Nov 13 2022, 07:04 AM
Michael Group: Members Posts: 9,750 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That is a very nice solution when using the TR firewall bushing. (IMG:style_emoticons/default/beerchug.gif)
jim_hoyland |
Nov 13 2022, 07:26 AM
Get that VIN ? Group: Members Posts: 9,287 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Im not clear how the adapter is held in place from the picture ?
davep |
Nov 13 2022, 07:56 AM
914 Historian Group: Benefactors Posts: 5,141 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
Jim, he says it is a slip fit, so expect that means a friction fit with possible degrees of looseness. Probably some silicone sealant would secure it and provide sealing against any water penetration.
peteinjp |
Nov 13 2022, 08:54 AM
Jim, he says it is a slip fit, so expect that means a friction fit with possible degrees of looseness. Probably some silicone sealant would secure it and provide sealing against any water penetration. Exactly- its just pressed onto the O.D. of the bushing carrier. I'll glue it on next time I have the car up. Pete |
peteinjp |
Nov 13 2022, 08:55 AM
That is a very nice solution when using the TR firewall bushing. (IMG:style_emoticons/default/beerchug.gif) Thanks- it was a fun little project. Sometimes that's the time I have for car stuff. |
jim_hoyland |
Nov 13 2022, 10:15 AM
Got it (IMG:style_emoticons/default/smile.gif) Great idea, I have the same situation.
nditiz1 |
Nov 13 2022, 12:43 PM
Senior Member Group: Members Posts: 1,187 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
I'm confused, did you have the issue before the TR bushing? It seems to me either the boot is not in spec or it wasn't put on properly. I only say this as the distance between the ring that the shift rod has is welded is a certain amount from the end of the rod which should be the same spec for any 914. That is then attached to the same fixed length spec rod going through the firewall. I'm not understanding how if all factory specs the boot would come off in 2,4,R unless the boot was never installed correctly over the firewall lip OR the boot is so worn it no longer retains the hold around the firewall flange.
ChrisFoley |
Nov 13 2022, 01:33 PM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I'm confused, did you have the issue before the TR bushing? It seems to me either the boot is not in spec or it wasn't put on properly. I only say this as the distance between the ring that the shift rod has is welded is a certain amount from the end of the rod which should be the same spec for any 914. That is then attached to the same fixed length spec rod going through the firewall. I'm not understanding how if all factory specs the boot would come off in 2,4,R unless the boot was never installed correctly over the firewall lip OR the boot is so worn it no longer retains the hold around the firewall flange. He has an early car. There is no ring on the firewall to retain that boot. The groove on my bushing carrier doesn't provide a lot of grip because the od of the carrier isn't quite large enough. |
Lo-Fi Version | Time is now: 13th May 2024 - 10:38 PM |
