FS: L Jetronic Fuel Injection system complete |
gtsdls |
Nov 13 2022, 03:34 PM
Newbie Group: Members Posts: 8 Joined: 28-November 03 From: Vestal, NY Member No.: 1,402 |
Removed from a 1975 (7 pin AFM) 1.8 which was running at the time. Additional pics available. PayPal accepted plus PP fee. Buyer responsible for actual shipping.
[attachmentid=857 679] Attached image(s) |
gtsdls |
Nov 13 2022, 03:35 PM
Price is $850.
jesiv |
Nov 28 2022, 11:17 AM
Senior Member Group: Members Posts: 552 Joined: 5-August 07 From: Pensacola/Milton, Florida Member No.: 7,975 Region Association: Northern California |
When was it last run?
JeffBowlsby |
Nov 28 2022, 07:17 PM
914 Wiring Harnesses Group: Members Posts: 8,507 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
One of the best 'complete FI system' ads I have ever seen. Hoping every component checks out as functional.
I am not your buyer but one question: is the 1.8L-only bolt on air filter box shelf included also... did not see it in the photos. |
Van B |
Nov 29 2022, 11:46 AM
Senior Member Group: Members Posts: 1,585 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
One of the best 'complete FI system' ads I have ever seen. Hoping every component checks out as functional. I am not your buyer but one question: is the 1.8L-only bolt on air filter box shelf included also... did not see it in the photos. It's there. you can see it attached to the airbox on the first pick. I'm sure much of this system is work out, but the really important NLA stuff that usually doesn't fail is all there and worth the price alone! |
StarBear |
Nov 29 2022, 11:48 AM
Senior Member Group: Members Posts: 1,884 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
One of the best 'complete FI system' ads I have ever seen. Hoping every component checks out as functional. I am not your buyer but one question: is the 1.8L-only bolt on air filter box shelf included also... did not see it in the photos. It's there. you can see it attached to the airbox on the first pick. I'm sure much of this system is work out, but the really important NLA stuff that usually doesn't fail is all there and worth the price alone! Indeed! Like the ECU, distributor and double stem vac can! |
2mAn |
Dec 14 2022, 12:53 AM
trying to see how long I can go without a 914 Group: Members Posts: 487 Joined: 14-November 13 From: Westchester (Los Angeles) Member No.: 16,644 Region Association: Southern California |
Can this work on a 912E?
Van B |
Dec 14 2022, 08:07 PM
JeffBowlsby |
Dec 14 2022, 11:18 PM
Can this work on a 912E? You’ll need to download the PET for both cars from the Porsche classic website, but there is quite a bit of cross compatibility Conceptually maybe, but practically speaking, I don't think so. The intake air plumbing and fuel delivery system/metering is 2.0L not 1.8L. I have built several 912E FI harnesses and they are significantly different internally and externally from the 914 L-Jet versions. How many differences can you spot in the 912E engine bay vs the 1.8L 914? Attached thumbnail(s) |
jesiv |
Dec 25 2022, 12:57 PM
Do you have pictures inside the AFM? Curious about west?
gtsdls |
Apr 1 2023, 05:07 PM
Do you have pictures inside the AFM? Curious about west? Bump- still for sale Prefer cash or cleared check. This system came off a running engine, and the parts have been boxed and stored for years. I tried to keep the parts as organized as possible. The LJetronic (according to several threads from the past) will support a larger displacement by using 2.0 runners, larger injectors and/or higher FI system pressure. |
gtsdls |
Mar 10 2024, 04:33 PM
Bump- still for sale @ $850
PP accepted, although I would prefer cash or cleared check. Shipping at buyers expense, we use PirateShip to find best rate... This system came off a running engine, and the parts have been boxed and stored for years. I tried to keep the parts as organized as possible. The LJetronic (according to several threads from the past) will support a larger displacement by using 2.0 runners, larger injectors and/or higher FI system pressure. |
gtsdls |
Apr 23 2024, 01:48 PM
Bump
Lo-Fi Version | Time is now: 16th May 2024 - 05:08 PM |
