Bosch 044 fuel pump |
mb911 |
Nov 30 2022, 06:46 AM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Where is the best place to get the 044 fuel pump. Prices are all over the place from $50 to $200. Are there counterfeit units out there?
914Sixer |
Nov 30 2022, 07:23 AM
Yes, counterfeits are everywhere. Watch the wording, they will say replacement for Bosch 044. I have an old NOS 012 if that will work?
Steve |
Nov 30 2022, 08:46 AM
914 Guru Group: Members Posts: 5,584 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I just bought one from Pegasus. It has been superseded with a new part number. Probably because of all the counterfeit 044 units. You can also find the below part number on Pelican and other sites.
https://www.pegasusautoracing.com/productde...sp?RecID=33077P |
mb911 |
Nov 30 2022, 10:19 AM
Yes, counterfeits are everywhere. Watch the wording, they will say replacement for Bosch 044. I have an old NOS 012 if that will work? Unfortunately I have now idea does it have the same specs as the 044? I am doing EFI over the winter on my -6 and the 044 is suggested. |
Steve |
Nov 30 2022, 10:56 AM
It's supposed to have the same specs as the 044 that it replaces. JW at Otto's installed the 044 on my 3.2. I'm installing this new pump on my Fitech fuel injection on my v8 car. The current Fitech pump is leaking and loosing pressure. You could call up Pelican and ask them. They also sell this pump. https://www.pelicanparts.com/More_Info/0580...580-464-200-M14 |
mb911 |
Nov 30 2022, 01:25 PM
It's supposed to have the same specs as the 044 that it replaces. JW at Otto's installed the 044 on my 3.2. I'm installing this new pump on my Fitech fuel injection on my v8 car. The current Fitech pump is leaking and loosing pressure. You could call up Pelican and ask them. They also sell this pump. https://www.pelicanparts.com/More_Info/0580...580-464-200-M14 Ok great. My 2.4 will be Weber/itb fuel injected this spring. |
Brett W |
Nov 30 2022, 01:27 PM
As long as you buy from a reputable motorsports dealer, they most likely won't be selling the counterfeit pumps.
stownsen914 |
Nov 30 2022, 06:41 PM
Senior Member Group: Members Posts: 913 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Bosch 044 feeds like 700 hp depending on whom you ask. No issue using one of course, but it might be overkill for most 911 builds.
Chris914n6 |
Nov 30 2022, 07:46 PM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Bosch has been combining OEM fuel pumps into similar spec replacements for a while. Basically a reduction of part numbers.
044 is usually for big turbo cars. I'll have to lookup the part# for mine but it's good for 300hp. 044, like the Walbro, has a counterfeit problem. |
mb911 |
Dec 1 2022, 06:17 AM
Bosch 044 feeds like 700 hp depending on whom you ask. No issue using one of course, but it might be overkill for most 911 builds. I am just planning on that because @jpnovak specs that for my EFI project |
Steve |
Dec 1 2022, 08:14 AM
It was used on my track 3.2 914 since it supports fittings on both sides for steel braided lines. I converted the car back to street, changed the fittings to barb fittings for rubber hose and kept the pump. Car runs awesome, but yes probably overkill. I will use the same pump when I replace the 3.2 with a 3.6.
T.Rick6 |
Dec 1 2022, 08:27 AM
Member Group: Members Posts: 51 Joined: 1-October 19 From: Douglasville, Ga Member No.: 23,512 Region Association: South East States |
[quote name='mb911' date='Nov 30 2022, 02:25 PM' post='3041956']
[quote name='Steve' post='3041916' date='Nov 30 2022, 08:56 AM'] It's supposed to have the same specs as the 044 that it replaces. JW at Otto's installed the 044 on my 3.2. I'm installing this new pump on my Fitech fuel injection on my v8 car. The current Fitech pump is leaking and loosing pressure. You could call up Pelican and ask them. They also sell this pump. https://www.pelicanparts.com/More_Info/0580...580-464-200-M14 [/quote] Ok great. My 2.4 will be Weber/itb fuel injected this spring. Mind expanding on your webber/ITB set-up; I'm looking for a FI sys for my 3.3 that's under 10k, Thank you sir... |
mb911 |
Dec 1 2022, 10:06 AM
[quote name='T.Rick6' date='Dec 1 2022, 06:27 AM' post='3042148']
[quote name='mb911' date='Nov 30 2022, 02:25 PM' post='3041956'] [quote name='Steve' post='3041916' date='Nov 30 2022, 08:56 AM'] It's supposed to have the same specs as the 044 that it replaces. JW at Otto's installed the 044 on my 3.2. I'm installing this new pump on my Fitech fuel injection on my v8 car. The current Fitech pump is leaking and loosing pressure. You could call up Pelican and ask them. They also sell this pump. https://www.pelicanparts.com/More_Info/0580...580-464-200-M14 [/quote] Ok great. My 2.4 will be Weber/itb fuel injected this spring. Mind expanding on your webber/ITB set-up; I'm looking for a FI sys for my 3.3 that's under 10k, Thank you sir... [/quote] I am using my carbs as throttle bodies and the injectors will be inserted into the MFI ports on the heads of my 2.4. It is simple and has been proven over the years by Jamie as he actually use to sell the kit on pelican. total cost will be about $1500 and look pretty stock |
Lo-Fi Version | Time is now: 13th May 2024 - 10:59 PM |
