[quote name='T.Rick6' date='Dec 1 2022, 06:27 AM' post='3042148']
[quote name='mb911' date='Nov 30 2022, 02:25 PM' post='3041956']
[quote name='Steve' post='3041916' date='Nov 30 2022, 08:56 AM']
It's supposed to have the same specs as the 044 that it replaces. JW at Otto's installed the 044 on my 3.2.
I'm installing this new pump on my Fitech fuel injection on my v8 car. The current Fitech pump is leaking and loosing pressure.
You could call up Pelican and ask them. They also sell this pump.
https://www.pelicanparts.com/More_Info/0580...580-464-200-M14[/quote]
Ok great. My 2.4 will be Weber/itb fuel injected this spring.
Mind expanding on your webber/ITB set-up; I'm looking for a FI sys for my 3.3 that's under 10k, Thank you sir...
[/quote]
I am using my carbs as throttle bodies and the injectors will be inserted into the MFI ports on the heads of my 2.4. It is simple and has been proven over the years by Jamie as he actually use to sell the kit on pelican.
total cost will be about $1500 and look pretty stock
