74 getting a new life |
Motosan |
Dec 2 2022, 11:10 PM
Newbie Group: Members Posts: 33 Joined: 14-October 22 From: California Member No.: 26,919 Region Association: Southern California |
Getting ready to start phase one of the build.
1974 2.0l Parts are all ready to go. 1.New rebuilt transaxle, tangerine racing shift linkage kit, and shift rod bearing. 2. Front and rear bilstein struts, camber plate bushings, ball joints, polybronze control arm bearings, low friction control arm bearings, bump steer kit, drop link bushings, polybronze trail arm bearings, and turbo tie rods. 3. Rebuilt front/rear calipers, pads, calipers, brake lines, tangerine racing master cylinder brace, and a 19mm master cylinder. 4. 914 rubber - door panels, full rubber/seal package, rs door handles, visor package, and h4 lens/led lights. 5. Refurbished dash, knee pad, font/rear targa pads, refurbished seats/center console pad, carpet kit, threshold trim, windshield, mono Indy steering wheel, and a retro manufacturing bluetooth radio. 6. Tangerine racing Evo exhaust and heat exchangers. Looking forward to giving this car a new life! |
Motosan |
Jan 27 2023, 11:12 PM
Rear bushings, struts, and exhaust all on. Just need to bleed the brakes and adjust the shifter before I finish the first stage of the build.
Attached thumbnail(s) |
CCE |
Jan 28 2023, 03:18 AM
CCE Group: Members Posts: 309 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille |
Rear bushings, struts, and exhaust all on. Just need to bleed the brakes and adjust the shifter before I finish the first stage of the build. Can I ask if the rear springs are the original ones, and in which ring clips did you fit the height on the bilsteins please. |
Motosan |
Jan 28 2023, 11:14 AM
Rear bushings, struts, and exhaust all on. Just need to bleed the brakes and adjust the shifter before I finish the first stage of the build. Can I ask if the rear springs are the original ones, and in which ring clips did you fit the height on the bilsteins please. We used the original springs(I think they are original anyways). They have three green paint marks. I went back and worth on replacing these but going to drive the car and see how it all turns out before replacing them. I used the very top clip as it seemed to line up with the original setup and was happy with the ride height. Won’t know for certain until the car is back on the ground, but I’m sure there is going to be some fine tuning with the setup. |
Lo-Fi Version | Time is now: 2nd May 2024 - 03:14 AM |
