Finally getting to the point of installing bright work, and then this |
Type 47 |
Dec 3 2022, 11:13 AM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Cairo94507 |
Dec 3 2022, 01:03 PM
Michael Group: Members Posts: 9,752 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
The good news is it a small piece; did you source it from 914 Rubber -(hopefully)? How is the other side? (IMG:style_emoticons/default/beerchug.gif)
Type 47 |
Dec 3 2022, 01:25 PM
The good news is it a small piece; did you source it from 914 Rubber -(hopefully)? How is the other side? (IMG:style_emoticons/default/beerchug.gif) other side is great. Yes, got it from 914 Rubber but 10 years ago. I figured it was an installation issue, so I've already reordered. |
Mikey914 |
Dec 3 2022, 02:33 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes, it's the same material we are sourced in Germany. Fortunately, I have never seen any variation between rolls.
Yes, I made this mistake early on. As these are cut so trimming is minimal, you need to check the installation to the parts to install to assure they are covered. Easy to do if you haven't done this before. -Mark |
Type 47 |
Dec 3 2022, 04:04 PM
Yes, it's the same material we are sourced in Germany. Fortunately, I have never seen any variation between rolls. Yes, I made this mistake early on. As these are cut so trimming is minimal, you need to check the installation to the parts to install to assure they are covered. Easy to do if you haven't done this before. -Mark I've not done this before, that's why I had the paint guys do it. I've got my son, a seasoned technician helping so I'm sure he will have it covered. Will we have to strip off the glue from the previous installation?? |
Mikey914 |
Dec 3 2022, 05:25 PM
I'd say yes. I had to. I was able to use goof off but may depend on material you used. I think I used the 3M super 90.
mlindner |
Dec 4 2022, 08:47 AM
Senior Member Group: Members Posts: 1,520 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Could that be steamed and stretch out. Best, Mark
Mikey914 |
Dec 4 2022, 09:48 AM
The material could be reused, but the problem is usually the glue from previous install makes it "lumpy"
Cairo94507 |
Dec 4 2022, 10:10 AM
Yup- Mark is absolutely right. Better to order a new piece. This material is pretty tough, in my experience it will not stretch out and stay. Even when laid out flat and glued, it may shrink a little bit over time. (IMG:style_emoticons/default/beerchug.gif)
Type 47 |
Dec 4 2022, 03:08 PM
Yup- Mark is absolutely right. Better to order a new piece. This material is pretty tough, in my experience it will not stretch out and stay. Even when laid out flat and glued, it may shrink a little bit over time. (IMG:style_emoticons/default/beerchug.gif) already ordered and was shipped on the 2nd |
Lo-Fi Version | Time is now: 14th May 2024 - 10:04 PM |
