FS: BMW 320i calipers |
PatMc |
Dec 3 2022, 02:57 PM
Member Group: Members Posts: 120 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
Freshly rebuilt…cad plated, new pistons, bleeders, kits, etc.. These have has a bit of grinder work on ‘em for wheel clearance on an early car, but nothing that compromises the calipers.
These have not been machined to fit the late 914, but I can do that if needed. $250 shipped obo I have some virgins (no grinder work) at the plating shop now getting done if anyone want a nice set lol. Attached thumbnail(s) |
bdstone914 |
Dec 3 2022, 06:00 PM
bdstone914 Group: Members Posts: 4,523 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Pat,
Are they ground down on the mounting pads or elsewhere? If the mounting pads are stock fit 70-72 cars with pinch bolt struts. If the mounting pads are ground down .125" they fit 72-76 cars with taper pin struts. Bruce |
914werke |
Dec 3 2022, 06:09 PM
"I got blisters on me fingers" Group: Members Posts: 10,082 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Bruce you can see that a PO had taken a grinder to the front caliper halves prior to plating
PatMc |
Dec 3 2022, 06:16 PM
Pat, Are they ground down on the mounting pads or elsewhere? If the mounting pads are stock fit 70-72 cars with pinch bolt struts. If the mounting pads are ground down .125" they fit 72-76 cars with taper pin struts. Bruce Grinding is visible in the picture on the outer halves. As stated, these have not been machined (or ground) to fit the later cars. I've seen a few sets on early cars that required come clearancing like this for the wheels...can't remember what wheels they were using though. |
markhoward |
Dec 3 2022, 08:49 PM
Member Group: Members Posts: 377 Joined: 5-March 17 From: Lafayette, CA Member No.: 20,897 Region Association: Northern California |
These calipers were on a 72 with early struts running 2.0 fuchs with 1/4” spacers. Hope that helps.
PatMc |
Feb 2 2023, 08:41 AM
bump
BadToTheBown |
Feb 2 2023, 12:05 PM
Newbie Group: Members Posts: 36 Joined: 12-July 20 From: ABQ NM Member No.: 24,488 Region Association: None |
jpapatrout |
Feb 18 2023, 04:34 PM
Newbie Group: Members Posts: 12 Joined: 7-October 09 From: SoCal - Palm Springs Member No.: 10,903 Region Association: Southwest Region |
Lo-Fi Version | Time is now: 21st May 2024 - 01:52 AM |
