2 Pages V < 1 2
> Boxster S Transaxle & 911 Carrera Axles: What spacers are needed?
mb911
post Dec 9 2022, 12:43 PM
Post #21
QUOTE(mepstein @ Dec 8 2022, 03:37 PM) *
QUOTE(mb911 @ Dec 8 2022, 06:29 PM) *
QUOTE(mepstein @ Dec 8 2022, 03:05 PM) *
QUOTE(tygaboy @ Dec 4 2022, 07:20 PM) *
@The Double S - That's the same set up I'm running in my LS car. You need:
- 1/2" spacers between the trans output shafts and the inner CVs along with appropriately longer bolts. Make your own spacer or contact Renegade Hybrids - they supplied mine.
- At the hub end, you'll need a special spacer from Patrick Motorsports, available here:
https://patrickmotorsports.com/collections/...914331aspextpms
I should get some of those 5mm spacers made up. At $50 + ship, it's a couple dollars of steel and doesn't cost much more to make ten sets. Maybe Ben should... @MB911
It's needed when you use the later hub centric 911 rear hubs.
Maybe. The hubs you sent me require this? Or did you send early 911 units?
I sent you early. They don't need the spacer. That's what you asked had for. I'll send you late if you prefer. no prob.
I used late on my suby build and a set for my future build and thought it was kind of silly to spend $100 on four little metal rings.
Ok great no worries. I am still confused what I have. I need to research that this winter so I am ready to go in spring.
The Double S
post Dec 9 2022, 12:53 PM
Post #22
Thanks Clay. I understand now and I didn't know that about the water cooled axles. Could have saved a couple steps.
The GKN axles I bought are for air cooled cars. The years listed were 1985.5 - 1988.
2 Pages V < 1 2
- Lo-Fi Version Time is now: 25th June 2026 - 04:31 PM
