WTB: fresh air hose, *******found****** |
jim_hoyland |
Dec 4 2022, 04:44 PM
Get that VIN ? Group: Members Posts: 9,277 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Looking for the hose that connects the middle dash vent to the mixer valve. This hose has two sharp turns at each end. Prefer an original hose
@914werke Update: Purchased a new 50mm piece of hose at local VW shop in Huntingto Beach. New hose is more flexible and went on with minimal force. Attached thumbnail(s) |
914Sixer |
Dec 5 2022, 07:21 AM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
The hose is standard VW size, Not sure what size hose is, thinking it is 50mm. Any VW site should have this vent size hose. Think URO makes reproduction.
jim_hoyland |
Dec 5 2022, 09:39 AM
I’d prefer one that came out of a 914 and has the two bends in it it’s a tight area to work in.
bdstone914 |
Dec 5 2022, 12:32 PM
bdstone914 Group: Members Posts: 4,516 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I’d prefer one that came out of a 914 and has the two bends in it it’s a tight area to work in. To hose runs from the mixer box to an elbow and has one bend. You should have a plastic elbow that bolt in from the trunk side that the vent plugs into. Most used hoses are brittle. New ones are cheap. https://www.pelicanparts.com/More_Info/3020...amp;q=021129087 Attached image(s) |
jim_hoyland |
Dec 5 2022, 12:56 PM
I’d prefer one that came out of a 914 and has the two bends in it it’s a tight area to work in. To hose runs from the mixer box to an elbow and has one bend. You should have a plastic elbow that bolt in from the trunk side that the vent plugs into. Most used hoses are brittle. New ones are cheap. https://www.pelicanparts.com/More_Info/3020...amp;q=021129087 Part 6 in the diagram faces upward; mine faces 90 degrees counterclockwise. It's a real tough compound bend. Im hoping someone has removed one; even a picture might help. And it is 50mm; |
Lo-Fi Version | Time is now: 9th May 2024 - 06:07 AM |
