QUOTE(bdstone914 @ Dec 5 2022, 10:32 AM)
QUOTE(jim_hoyland @ Dec 5 2022, 09:39 AM)
I’d prefer one that came out of a 914 and has the two bends in it it’s a tight area to work in.
To hose runs from the mixer box to an elbow and has one bend. You should have a plastic elbow that bolt in from the trunk side that the vent plugs into. Most used hoses are brittle. New ones are cheap.
https://www.pelicanparts.com/More_Info/3020...amp;q=021129087Part 6 in the diagram faces upward; mine faces 90 degrees counterclockwise. It's a real tough compound bend.
Im hoping someone has removed one; even a picture might help. And it is 50mm;
