Houston, We have a problem |
Type 47 |
Dec 5 2022, 09:49 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
windforfun |
Dec 5 2022, 09:53 PM
Senior Member Group: Members Posts: 1,785 Joined: 17-December 07 From: Blackhawk, CA Member No.: 8,476 Region Association: None |
Isn't that the nut on the right of the pic? Can you get into the long below the heater tube? Is a washer missing?
Type 47 |
Dec 5 2022, 10:38 PM
Isn't that the nut on the right of the pic? Can you get into the long below the heater tube? Is a washer missing? that nut is just a rogue nut put on to keep the belt bolt in place. Ther are specific washers for this bolt. The issue is the receptacle for the bolt that should be welded on the inside is missing. |
930cabman |
Dec 6 2022, 05:56 AM
Advanced Member Group: Members Posts: 3,062 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
One of the most famous lines from the last century.
RD has this: https://www.restoration-design.com/store/product/PP339C how firm could it possibly have been attached? |
gereed75 |
Dec 6 2022, 07:27 AM
Senior Member Group: Members Posts: 1,246 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Assuming the car is not a concurs queen….Cut a 1.5 x 3” plate of 3/16th plate steel. Drill a hole in center. Weld the nut to the backside. Unibit the hole in the long to allow the just fabricated nut plate to sit flush. Clean off the paint from around the hole. Weld prime and then weld this nut plate into place. Touch up paint. Viola.
914Sixer |
Dec 6 2022, 07:29 AM
You might try putting a steel blind nut in there to correct your problem
Attached thumbnail(s) |
Dion |
Dec 6 2022, 07:34 AM
RN Group: Members Posts: 2,765 Joined: 16-September 04 From: Audubon,PA Member No.: 2,766 Region Association: MidAtlantic Region |
Hopefully it’s not like this on the other side of the nice paint.
Dion |
Dec 6 2022, 07:36 AM
Otherwise you’ll need Resto design for this.
Olympic 914 |
Dec 6 2022, 08:11 AM
Group: Members Posts: 1,668 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Had a similar problem, when the longs were repaired the seat belt attachment was forgotten.
I did pretty much what @Gereed75 suggested. But wanting a lathe project I machined a threaded piece, then welded it behind the plate. used a hole saw to cut the hole in the long big enough to fit the flange. Its not coming loose. |
930cabman |
Dec 6 2022, 08:17 AM
Could be someone's life with the integrity of this connection, take your time and get it right
gereed75 |
Dec 6 2022, 08:24 AM
Nice Tom. That should do it!
Type 47 |
Dec 6 2022, 11:00 AM
Assuming the car is not a concurs queen….Cut a 1.5 x 3” plate of 3/16th plate steel. Drill a hole in center. Weld the nut to the backside. Unibit the hole in the long to allow the just fabricated nut plate to sit flush. Clean off the paint from around the hole. Weld prime and then weld this nut plate into place. Touch up paint. Viola. Trying to make it a nice rust free car...but by no means will it ever be in a concurs. THANKS EVERYONE. The pictures and links were super helpful. We got to figure out how to crack it open but after that my son can weld a solid, safe, solution there. |
Dec 6 2022, 11:45 AM
Resident German Group: Admin Posts: 41,638 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
You might try putting a steel blind nut in there to correct your problem I would not trust that "solution" with my life. (IMG:style_emoticons/default/shades.gif) |
dr914@autoatlanta.com |
Dec 6 2022, 12:10 PM
914 Guru Group: Members Posts: 7,857 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
we make the weld nut plates we sell them
somewhere along the way...probably with Bob the media blaster... missing the anchor (nut??) for the passenger side seat belt. My passengers are usually looking for some kind of O Jesus handle, hate to tell them their seat belt is anchored by some JB weld. How do I fix this? |
nathanxnathan |
Dec 6 2022, 12:48 PM
Member Group: Members Posts: 278 Joined: 16-February 18 From: Laguna Beach, CA Member No.: 21,899 Region Association: Southern California |
Lo-Fi Version | Time is now: 16th May 2024 - 06:53 AM |
