FS 911 steering column/ignition/switches, package for a conversion to 914-6 conversion |
jim dorociak |
Dec 7 2022, 01:05 PM
Member Group: Members Posts: 95 Joined: 23-January 09 From: Newbury Park, Ca Member No.: 9,966 Region Association: Southern California |
*******SOLD********
I have an early 911 steering column that I removed the bracket and then had a late model 914 column brace welded on. Unit was then sent out to be plated. I also have a 911 ignition switch/key, 911 wiper column switch as well as the turn signal column switch for the other side. Package deal and get everything at one time $975 plus shipping and PayPal fees. jdorociak@gmail.com. Jim *******SOLD******** Thank you! |
jim dorociak |
Dec 9 2022, 04:18 PM
$975 and it includes shipping. NEW price LOWER. . . .
Jett |
Dec 9 2022, 04:29 PM
Senior Member Group: Members Posts: 1,637 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I’ll take it (IMG:style_emoticons/default/smile.gif) had no plans of moving the ignition, but this makes it easy.
Please send me PP instructions |
Dec 9 2022, 05:22 PM
914-6 GT in waiting Group: Members Posts: 19,258 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I’ll take it (IMG:style_emoticons/default/smile.gif) had no plans of moving the ignition, but this makes it easy. Please send me PP instructions Just make sure you use it in a 72 or later chassis. Early uses a different steering column mount. |
Jett |
Dec 9 2022, 06:22 PM
I’ll take it (IMG:style_emoticons/default/smile.gif) had no plans of moving the ignition, but this makes it easy. Please send me PP instructions Just make sure you use it in a 72 or later chassis. Early uses a different steering column mount. Thanks Mark… had no idea. We are using a 75 chassis so this will not work (IMG:style_emoticons/default/sad.gif) Sorry! |
jim dorociak |
Dec 9 2022, 06:40 PM
this is using a late 914 bracket so it will work. I have another column that has no bracket welded on if you would rather have that one. jdorociak@gmail.com
This was for my 75 conversion that is for sale. Jim |
Dec 9 2022, 06:42 PM
I’ll take it (IMG:style_emoticons/default/smile.gif) had no plans of moving the ignition, but this makes it easy. Please send me PP instructions Just make sure you use it in a 72 or later chassis. Early uses a different steering column mount. Thanks Mark… had no idea. We are using a 75 chassis so this will not work (IMG:style_emoticons/default/sad.gif) Sorry! It should work fine in a 75. 70-71 requires a custom made bracket. 72-76 can use a bracket like the one shown. @jett |
Jett |
Dec 9 2022, 09:02 PM
I’ll take it (IMG:style_emoticons/default/smile.gif) had no plans of moving the ignition, but this makes it easy. Please send me PP instructions Just make sure you use it in a 72 or later chassis. Early uses a different steering column mount. Thanks Mark… had no idea. We are using a 75 chassis so this will not work (IMG:style_emoticons/default/sad.gif) Sorry! It should work fine in a 75. 70-71 requires a custom made bracket. 72-76 can use a bracket like the one shown. @jett That’s great! |
Jett |
Dec 9 2022, 09:08 PM
I’ll take it (IMG:style_emoticons/default/smile.gif) had no plans of moving the ignition, but this makes it easy. Please send me PP instructions Just make sure you use it in a 72 or later chassis. Early uses a different steering column mount. Thanks Mark… had no idea. We are using a 75 chassis so this will not work (IMG:style_emoticons/default/sad.gif) Sorry! Sorry misread Mark’s advice. Item purchased. Thanks |
jim dorociak |
Dec 9 2022, 09:26 PM
money received! thank you! Jim
Lo-Fi Version | Time is now: 9th May 2024 - 10:56 PM |
