Parts for 2056, Where to source parts |
sjhenry1075 |
Dec 8 2022, 09:22 AM
Member Group: Members Posts: 266 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
Hey everyone,
I'm in the process of sourcing parts for my 2056 build. I was able to find 2.0 heads that will be rebuilt by a local machine shop, and I found a set of very nice 40 IDF Weber carbs. I'll also be using my 1.7 case. My question is this: for the engine internals, where can I find these parts? I did see on the Fat Rimco website that they sell a short block kit for $2650 that includes the following: FAT Camshaft FC 442 Camshaft / FC 440 If Smog 71mm Type 4 Crankshaft 2.0 Connecting Rods - Rebuilt 96mm Forged Pistons & Cylinders - Keith Black WEB Lifters Front Oil Seal Rear Main Seal Gasket Set - German Engine Hardware Kit - Nuts & Bolts Main Bearings - Silverline Rod Bearings - Mahle HD Double Thrust Cam Bearings (2 Sets of STD) What does everyone think about the price? I know some would not refer Fat Rimco for an engine build, but they will just supply the parts, not doing the actual build. Thoughts? |
914werke |
Dec 8 2022, 11:16 AM
"I got blisters on me fingers" Group: Members Posts: 10,050 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
If you local machine shop has the ability to do the heads Its a good bet that can handle the Rod & Crank rehab which allows you to PU core parts for reasonable?
Lo-Fi Version | Time is now: 8th May 2024 - 03:42 PM |
