Parts for 2056, Where to source parts |
sjhenry1075 |
Dec 8 2022, 09:22 AM
Member Group: Members Posts: 266 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
Hey everyone,
I'm in the process of sourcing parts for my 2056 build. I was able to find 2.0 heads that will be rebuilt by a local machine shop, and I found a set of very nice 40 IDF Weber carbs. I'll also be using my 1.7 case. My question is this: for the engine internals, where can I find these parts? I did see on the Fat Rimco website that they sell a short block kit for $2650 that includes the following: FAT Camshaft FC 442 Camshaft / FC 440 If Smog 71mm Type 4 Crankshaft 2.0 Connecting Rods - Rebuilt 96mm Forged Pistons & Cylinders - Keith Black WEB Lifters Front Oil Seal Rear Main Seal Gasket Set - German Engine Hardware Kit - Nuts & Bolts Main Bearings - Silverline Rod Bearings - Mahle HD Double Thrust Cam Bearings (2 Sets of STD) What does everyone think about the price? I know some would not refer Fat Rimco for an engine build, but they will just supply the parts, not doing the actual build. Thoughts? |
BeatNavy |
Dec 9 2022, 10:50 AM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Steve, I have a 2056 with a 9590 sitting on my garage floor. I only ran it a few hundred miles before i swapped in the 2258 (also with 9590).
Interesting you've selected that cam, as that's marketed/designed as FI-compatible. I guess if you ever wanted to switch over to FI you could then do so. It's a great cam, although on the first start of the day it needs about 30 seconds of throttle-feathering before the idle settles in nicely. |
Lo-Fi Version | Time is now: 8th May 2024 - 12:47 PM |
