Parts for 2056, Where to source parts |
sjhenry1075 |
Dec 8 2022, 09:22 AM
Member Group: Members Posts: 266 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
Hey everyone,
I'm in the process of sourcing parts for my 2056 build. I was able to find 2.0 heads that will be rebuilt by a local machine shop, and I found a set of very nice 40 IDF Weber carbs. I'll also be using my 1.7 case. My question is this: for the engine internals, where can I find these parts? I did see on the Fat Rimco website that they sell a short block kit for $2650 that includes the following: FAT Camshaft FC 442 Camshaft / FC 440 If Smog 71mm Type 4 Crankshaft 2.0 Connecting Rods - Rebuilt 96mm Forged Pistons & Cylinders - Keith Black WEB Lifters Front Oil Seal Rear Main Seal Gasket Set - German Engine Hardware Kit - Nuts & Bolts Main Bearings - Silverline Rod Bearings - Mahle HD Double Thrust Cam Bearings (2 Sets of STD) What does everyone think about the price? I know some would not refer Fat Rimco for an engine build, but they will just supply the parts, not doing the actual build. Thoughts? |
BeatNavy |
Dec 9 2022, 11:04 AM
I should also add that the 9590, when used with FI, is really designed (per Jake) for a target CR of 8.5 (max).
As Jake says, "it's all in the combo...." |
sjhenry1075 |
Dec 9 2022, 12:00 PM
I should also add that the 9590, when used with FI, is really designed (per Jake) for a target CR of 8.5 (max). As Jake says, "it's all in the combo...." I read through some previous threads about cams which is how I got the idea. I noted how it can be difficult to keep it running when cold. now that you mention that it was designed for FI, I wonder if I should go with something a little more geared towards carbs. I just don't want to leave any power on the table. |
Lo-Fi Version | Time is now: 8th May 2024 - 11:01 AM |
