Parts for 2056, Where to source parts |
sjhenry1075 |
Dec 8 2022, 09:22 AM
Member Group: Members Posts: 266 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States |
Hey everyone,
I'm in the process of sourcing parts for my 2056 build. I was able to find 2.0 heads that will be rebuilt by a local machine shop, and I found a set of very nice 40 IDF Weber carbs. I'll also be using my 1.7 case. My question is this: for the engine internals, where can I find these parts? I did see on the Fat Rimco website that they sell a short block kit for $2650 that includes the following: FAT Camshaft FC 442 Camshaft / FC 440 If Smog 71mm Type 4 Crankshaft 2.0 Connecting Rods - Rebuilt 96mm Forged Pistons & Cylinders - Keith Black WEB Lifters Front Oil Seal Rear Main Seal Gasket Set - German Engine Hardware Kit - Nuts & Bolts Main Bearings - Silverline Rod Bearings - Mahle HD Double Thrust Cam Bearings (2 Sets of STD) What does everyone think about the price? I know some would not refer Fat Rimco for an engine build, but they will just supply the parts, not doing the actual build. Thoughts? |
BeatNavy |
Dec 9 2022, 01:58 PM
Yeah, in and of itself, the higher CR wouldn't cause the failure. I believe the target CR for that cam is primarily based on getting a usable vacuum signal for FI, particularly at idle.
Steve, I'm not sure if it's necessarily BAD to use that cam with carbs (others can comment). But the point is you CAN get a more aggressive cam, and at least a bit more HP, with carbs since you don't have to worry about a usable FI signal. Again, flip side is you could convert to FI down the road with that cam if you really wanted to. |
Lo-Fi Version | Time is now: 8th May 2024 - 02:19 PM |
