bossboy302 |
Member ![]() ![]() Group: Members Posts: 88 Joined: 13-December 21 From: NorCal Member No.: 26,158 Region Association: None ![]() |
CRS!
Thought I'd read somewhere about removing the 4-cylinder mounting ears on the body when doing a 6-cyl. conversion. Can't find anything... Possibly part of the same dream as the one when Im actually driving it... |
mb911 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,625 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest ![]() ![]() |
CRS! Thought I'd read somewhere about removing the 4-cylinder mounting ears on the body when doing a 6-cyl. conversion. Can't find anything... Possibly part of the same dream as the one when Im actually driving it... I suggest removing them to allow for additional space. Some leave them in. I am not sure there really is a thread on it though |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,045 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I left mine in only because I was too lazy to remove them. It won’t hurt to leave them but it’s a nicer job if you take them out. It’s a messy job but there’s often rust behind the mounts so it’s worth doing.
Actually I did have the mounts removed on a chassis that I’m converting. There was a big rust spot behind the passenger mount. |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,351 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
Not much to add here other than if you do choose to remove, keep in mind the R. side mount can be valuable to folks doing rust-oration.
This is a part not yet being reproduced & is often compromised. |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,046 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I also do not recall a thread about this... I'm sure there are some pictures in a build thread but may not be specifics....
its like all of the other body work threads... spot weld drill bit(s) ... lots of time... and a bit of clean up when your done. brant |
Here’s my other car
Attached image(s) ![]() ![]() ![]() |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,923 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
I removed mine on my six conversion and like Mepstein, mine had rust behind the mount on the passenger side. I cleaned it up, but the area was weekend and eventually cracked and we had to add a scab plate. This does give you more room to adjust the valves on the six, but with the high cost of six motors, it will also not allow you to go to a lower cost motor in the future like Subi or LS.
bossboy302 |
Thank you all for the replies! Very helpful, esp. the photos. Thanks again, Brian
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,820 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
You can just cut them off and leave the plates the are spot welded to the body. It's not that big of a job and gives you the room. I did it a long time ago.
Krieger |
RKramden |
Newbie ![]() Group: Members Posts: 47 Joined: 26-October 19 From: So. California Member No.: 23,589 Region Association: Southern California ![]() |
I am going to flip the top receiver to the bottom with the radius side down which fits nicely on my jack stands
Lo-Fi Version | Time is now: 31st August 2025 - 02:46 PM |
