Stereo questions, Battery and alternator issues |
Motosan |
Dec 13 2022, 01:01 PM
Newbie Group: Members Posts: 33 Joined: 14-October 22 From: California Member No.: 26,919 Region Association: Southern California |
Sorry if this has been covered before but just wanted to ask before I jump into this on my project.
The 914 I am restoring has a single din head unit that I have just decided to replace with a new unit. I would like to install a pair of speakers(using the 914 rubber speaker pods) and a very small amp in addition to the new head unit. The car already seems to drop voltage with any extra demand, so I’m trying to go about this the best way possible. Would upgrading the battery and running a separate fuse block be the best option? I was looking at an Odyssey pc925 as a possible option. Thanks! |
Mikey914 |
Dec 13 2022, 01:50 PM
The rubber man Group: Members Posts: 12,639 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Check your battery, check your grounds, check your alternator output and the harness. Iwould run an extra fuse, but unless your drawing a significant amperage that should cover it.
You can go to LED headlights to reduce a consumer. I know a guy. (IMG:style_emoticons/default/sunglasses.gif) |
porschetub |
Dec 13 2022, 01:51 PM
Sorry if this has been covered before but just wanted to ask before I jump into this on my project. The 914 I am restoring has a single din head unit that I have just decided to replace with a new unit. I would like to install a pair of speakers(using the 914 rubber speaker pods) and a very small amp in addition to the new head unit. The car already seems to drop voltage with any extra demand, so I’m trying to go about this the best way possible. Would upgrading the battery and running a separate fuse block be the best option? I was looking at an Odyssey pc925 as a possible option. Thanks! I ran a separate hella fuse block under the dash and powered it with fused supply direct from the battery,I did plan on a small sub but not happening now but still good to have the stereo thats not powered of the stock fuseboard. |
FlacaProductions |
Senior Member Group: Members Posts: 1,565 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Greetings,
Start with this thread - I did nearly exactly what Brent @BBrock did with the same amp, speakers and wiring setup. I fished my main power wire though the speedo cable hole rather than the snorkel. Add the head of your choice. Just last week, I added a small, powered sub that REALLY filled things out - I couldn't be happier. http://www.914world.com/bbs2/index.php?s=&...t&p=2801031 |
Motosan |
Dec 13 2022, 02:04 PM
Check your battery, check your grounds, check your alternator output and the harness. Iwould run an extra fuse, but unless your drawing a significant amperage that should cover it. You can go to LED headlights to reduce a consumer. I know a guy. (IMG:style_emoticons/default/sunglasses.gif) I included the led bulb replacements in my last order with you! I just received two very large boxes yesterday! Thanks!! |
Motosan |
Dec 13 2022, 02:05 PM
Greetings, Start with this thread - I did nearly exactly what Brent @BBrock did with the same amp, speakers and wiring setup. I fished my main power wire though the speedo cable hole rather than the snorkel. Add the head of your choice. Just last week, I added a small, powered sub that REALLY filled things out - I couldn't be happier. http://www.914world.com/bbs2/index.php?s=&...t&p=2801031 Exactly what I was looking for! I appreciate it. |
Chris914n6 |
Dec 13 2022, 05:45 PM
Jackstands are my life. Group: Members Posts: 3,305 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
The 914 wiring could barely handle 70s stereo needs. I ran a dedicated 8 gauge to a fuse block under the dash.
Any standard size battery will handle a HU and 2 channel amp to 6.5" speakers and a powered sub small enough to fit in a 914. If you have any voltage problems it will be at night with all the lights on, in which case just buy LEDs, as they are a worthwhile upgrade on their own. |
porschetub |
Dec 13 2022, 09:24 PM
gereed75 |
Dec 14 2022, 08:28 AM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
Check this option http://www.914world.com/bbs2/index.php?sho...mp;hl=Subwoofer
Reallly like this. Draws very little amperage |
sb914 |
Dec 14 2022, 08:36 AM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Check your battery, check your grounds, check your alternator output and the harness. Iwould run an extra fuse, but unless your drawing a significant amperage that should cover it. You can go to LED headlights to reduce a consumer. I know a guy. (IMG:style_emoticons/default/sunglasses.gif) I included the led bulb replacements in my last order with you! I just received two very large boxes yesterday! Thanks!! Nice quiver ! |
GregAmy |
Dec 14 2022, 08:56 AM
Advanced Member Group: Members Posts: 2,268 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
dr914@autoatlanta.com |
Dec 14 2022, 09:31 AM
914 Guru Group: Members Posts: 7,820 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
nothing extra needed, with the unit wired properly the current alternator and wiring will work just fine without adding anything. You may also want to install a sub woofer where the passenger foam filler is located
Sorry if this has been covered before but just wanted to ask before I jump into this on my project. The 914 I am restoring has a single din head unit that I have just decided to replace with a new unit. I would like to install a pair of speakers(using the 914 rubber speaker pods) and a very small amp in addition to the new head unit. The car already seems to drop voltage with any extra demand, so I’m trying to go about this the best way possible. Would upgrading the battery and running a separate fuse block be the best option? I was looking at an Odyssey pc925 as a possible option. Thanks! |
Garland |
Dec 14 2022, 09:41 AM
Restoration Fanatic Group: Members Posts: 1,327 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
In 2016 I installed a powered sub, and an Alpine amp for the factory located speakers, and a set of satellite speakers. Factory alternator, See my build link at the bottom of the post for details.
Motosan |
Dec 15 2022, 11:54 PM
Check your battery, check your grounds, check your alternator output and the harness. Iwould run an extra fuse, but unless your drawing a significant amperage that should cover it. You can go to LED headlights to reduce a consumer. I know a guy. (IMG:style_emoticons/default/sunglasses.gif) I included the led bulb replacements in my last order with you! I just received two very large boxes yesterday! Thanks!! Nice quiver ! Thanks! They are all fun in their own way. |
Mikey914 |
Dec 17 2022, 10:04 PM
The LEDs are a HUGE upgrade. You will like them.
Spoke |
Dec 18 2022, 01:27 PM
Jerry Group: Members Posts: 6,977 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
As others have mentioned, the voltage droop you see in the 914 is mainly due to the 50 year old wiring and connectors. Your best bet is to run a separate wire directly from the battery to the amp. If it's a big amp you may want to place one of those 1F capacitors next to the amp for plenty of instantaneous energy.
barnfind9141972 |
Dec 18 2022, 10:39 PM
Member Group: Members Posts: 101 Joined: 10-December 20 From: Rancho Mirage, CA Member No.: 24,976 Region Association: Southern California |
I use an 8 inch subwoofer in a fiberglass custom enclosure that’s an exact spec of the foam block and an amplifier underneath the passenger seat. The amplifier has a power straight from the battery with a fuse and I have two JBL 6.5 speakers in 914Rubber enclosures wired directly to a pioneer head unit that’s powered by the empty accessory block on the fuse panel and the cigar lighter. 0 voltage drop and no issues on a Walmart battery.
DC_neun_vierzehn |
Jan 28 2023, 10:01 PM
Member Group: Members Posts: 377 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Good stuff in this thread. Thanks all.
CCE |
Jan 30 2023, 11:14 AM
CCE Group: Members Posts: 309 Joined: 28-December 21 From: Mexico Member No.: 26,203 Region Association: NineFourteenerVille |
I use an 8 inch subwoofer in a fiberglass custom enclosure that’s an exact spec of the foam block and an amplifier underneath the passenger seat. The amplifier has a power straight from the battery with a fuse and I have two JBL 6.5 speakers in 914Rubber enclosures wired directly to a pioneer head unit that’s powered by the empty accessory block on the fuse panel and the cigar lighter. 0 voltage drop and no issues on a Walmart battery. Do you have an image on how it looks? I have an 8” sub, that I could use. |
914pipe |
Feb 1 2023, 10:56 AM
Say......TEEEEEEEN!!!!! Group: Members Posts: 346 Joined: 31-July 04 From: Puerto Rico, now NC Member No.: 2,422 Region Association: South East States |
This is my configuration and is more than enough.
https://www.amazon.com/Hifonics-TPS-A350-4-...32-63e904010ad0 https://www.amazon.com/JBL-GTO629-Premium-6...386675&th=1 And a dual coil sub-woofer (2ohms each coil) fitted in the passenger foot rest. The amp is very small. I fixed behind the glove compartment. LOUD!!!! |
Lo-Fi Version | Time is now: 28th April 2024 - 08:44 PM |
