Engine Sound Mat Plugs, Yet Another Mystery - 3 or 4? |
StarBear |
Dec 18 2022, 11:55 AM
Senior Member Group: Members Posts: 1,851 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States |
OK; as I'm continuing to comb through various tidbit parts, I've come across this mystery (to me). Asking for any insights, experience, or wisdom.
The engine sound-deadening mat has several plastic attachment plugs, part # 914 559 377 10; on PET Section 8, Diagram 807-10, #14. It has a barbed plug end and the PET (and other sources) show 4 are required. See photo. Yet, mine (largely unmolested) has only 3. See photo. There are two other holes along the left wall and right wall (hidden by the battery), the backsides of what I presume are the seat belt retractors, but these are wide and are filled in by the bolt end - nowhere for a barbed tip to attached. BTW, I've been using more of a mushroom cap to cover them. See 3 photos. Question 1: If four are used, where the heck does the fourth one go?? Question 2: Might four have been used in early (70-71?) models and PET, etc not updated? I'm so very confused. Plastic Plug: Three plugs holding mat: Larger holes from seat belt (?) bolts: Mushroom cap I use: |
StarBear |
Dec 18 2022, 02:15 PM
wonkipop |
Dec 18 2022, 03:55 PM
Advanced Member Group: Members Posts: 4,247 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
only 3 in mine.
unless one is hidden somewhere i can't see. and i've looked and i don't see a 4th. one each side and one in middle. dunno about early cars. don't think they changed the sound mat? wouldn't be the first time the PET is wrong on quantities. refer lack of accurate info on late rain tray fixings. (IMG:style_emoticons/default/smile.gif) i've found other stuff too that is typos. nothing goes in holes for seat belt fixings. (IMG:style_emoticons/default/beerchug.gif) |
StarBear |
Dec 22 2022, 06:11 AM
Thank, mate! Guess I have a spare one now.
JeffBowlsby |
Dec 22 2022, 12:08 PM
914 Wiring Harnesses Group: Members Posts: 8,480 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Where did you get 'em? I need a few.
TonyA |
Dec 22 2022, 04:43 PM
Nachmal Group: Members Posts: 460 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
OK; as I'm continuing to comb through various tidbit parts, I've come across this mystery (to me). Asking for any insights, experience, or wisdom. The engine sound-deadening mat has several plastic attachment plugs, part # 914 559 377 10; on PET Section 8, Diagram 807-10, #14. It has a barbed plug end and the PET (and other sources) show 4 are required. See photo. Yet, mine (largely unmolested) has only 3. See photo. There are two other holes along the left wall and right wall (hidden by the battery), the backsides of what I presume are the seat belt retractors, but these are wide and are filled in by the bolt end - nowhere for a barbed tip to attached. BTW, I've been using more of a mushroom cap to cover them. See 3 photos. Question 1: If four are used, where the heck does the fourth one go?? Question 2: Might four have been used in early (70-71?) models and PET, etc not updated? I'm so very confused. Plastic Plug: Three plugs holding mat: Larger holes from seat belt (?) bolts: Mushroom cap I use: I think the fourth one goes in the center towards the top where the pad splts. See the attached picture ( notice the pads matches my shoes (IMG:style_emoticons/default/smile.gif) |
StarBear |
Dec 22 2022, 08:13 PM
OK; as I'm continuing to comb through various tidbit parts, I've come across this mystery (to me). Asking for any insights, experience, or wisdom. The engine sound-deadening mat has several plastic attachment plugs, part # 914 559 377 10; on PET Section 8, Diagram 807-10, #14. It has a barbed plug end and the PET (and other sources) show 4 are required. See photo. Yet, mine (largely unmolested) has only 3. See photo. There are two other holes along the left wall and right wall (hidden by the battery), the backsides of what I presume are the seat belt retractors, but these are wide and are filled in by the bolt end - nowhere for a barbed tip to attached. BTW, I've been using more of a mushroom cap to cover them. See 3 photos. Question 1: If four are used, where the heck does the fourth one go?? Question 2: Might four have been used in early (70-71?) models and PET, etc not updated? I'm so very confused. Plastic Plug: Three plugs holding mat: Larger holes from seat belt (?) bolts: Mushroom cap I use: I think the fourth one goes in the center towards the top where the pad splts. See the attached picture ( notice the pads matches my shoes (IMG:style_emoticons/default/smile.gif) Ahhhhh…. Will check there. |
wonkipop |
Dec 22 2022, 08:15 PM
@TonyA
you are dead right. just stuck my head right up in there and sure enough there was #4 on mine but broken off. its hidden by the engine lid hanging down when you open the lid. thanks for pointing that out. never would have spotted it unless i was hanging upside in the engine bay. (IMG:style_emoticons/default/biggrin.gif) @StarBear , if you figure out where to get these plugs let me know. i'll order myself up one to replace my broken one. |
StarBear |
Dec 22 2022, 08:17 PM
Where did you get 'em? I need a few. @jeffbowlsby I got the extra one via the kind generosity of @914sixer . For new ones, both AA and 914Rubber have them. I think that AA ones look more accurate. They are sold individually (per above, now looks like 4 per car, as indicated in PET or chart listings). @TonyA |
L-Jet914 |
Dec 22 2022, 11:34 PM
Member Group: Members Posts: 237 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I was just in my garage after I saw the mention. I found the 4th one as well as you mentioned. Mine is there but the head of the push clip is broken off mostly and I am missing the one underneath it. I will have to get new ones haha. Both of your silencer pads are in much better condition haha. Mine is definitely releasing from the rear firewall (adhesive letting go). It looks like they used horse hair or something with the rubber padding.
bbrock |
Dec 27 2022, 12:02 PM
You can pick up the plugs at NAPA (P/N 665-3116). Pretty sure those are the exact items AA sells as George is the one who posted the NAPA P/N a few years ago.
wonkipop |
Dec 27 2022, 04:11 PM
You can pick up the plugs at NAPA (P/N 665-3116). Pretty sure those are the exact items AA sells as George is the one who posted the NAPA P/N a few years ago. thanks for the tip. is this it. part no. is 665-3166, slightly different. looks like NAPA has established itself in australia. i think i can get these down here. |
bbrock |
Dec 27 2022, 04:31 PM
You can pick up the plugs at NAPA (P/N 665-3116). Pretty sure those are the exact items AA sells as George is the one who posted the NAPA P/N a few years ago. thanks for the tip. is this it. part no. is 665-3166, slightly different. looks like NAPA has established itself in australia. i think i can get these down here. I'm sure that has to be it. The dash in the # I posted was copied from what George posted in the other thread. I found mine hanging on a rack with the other various panel fasteners in the store. Didn't even have to bug the guy at the parts counter. |
StarBear |
Dec 28 2022, 02:52 PM
Here it is - hidden in not plain sight all along. Who’da guessed?
Helpful thread none the less. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 06:26 PM |
