what is the way to clean the aluminum impeller housing?, and make it look awesome like you guy's rides |
Type 47 |
Dec 18 2022, 09:31 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Not sure if "you guys" is proper English or not, maybe I should have said you'uns or youall: y'alls.
Anyway, I put some vinegar on it and it kinda looked at me, with that "what are you stupid" look, so then I used some muratic acid, like they use in pools. It started smoking and making bad smells . I got the "what are you really stupid" look as I coughed off outside, and I thought maybe I should go inside and ask the folks with the nice looking engine bays what to do. |
iankarr |
Dec 18 2022, 10:07 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,473 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
There’s magnesium in the housing. It will react to hydrochloric acid by turning the metal into hydrogen gas. No bueno.
I like to have the housings soda blasted. Then you can decide whether to coat it. There’s a rattle can paint called “alumi-blast” which I think looks good. But you have to make sure everything is super clean. Good luck and, as they said at Woodstock, stay away from the acid, man… |
914sgofast2 |
Dec 18 2022, 10:08 PM
Senior Member Group: Members Posts: 616 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Read the "1.8 cheap junk rebuild" thread over on the Type4Forum or the 411/412 forum on the Samba.com for cleaning do's and don'ts.
PatMc |
Dec 19 2022, 08:08 AM
Member Group: Members Posts: 120 Joined: 27-June 21 From: Long Beach Member No.: 25,669 Region Association: None |
Glass bead blast and a good coat of 2K clearcoat makes aluminum look good and stay looking good.
Keep acids / caustic cleaners away from aluminum and magnesium |
Type 47 |
Dec 19 2022, 10:53 AM
Thanks guys. super helpful
maf914 |
Dec 19 2022, 05:07 PM
I like to have the housings soda blasted. Then you can decide whether to coat it. There’s a rattle can paint called “alumi-blast” which I think looks good. But you have to make sure everything is super clean. Aluma Blast is an Eastwood paint product. https://www.eastwood.com/search/?q=aluma%20blast |
Type 47 |
Dec 19 2022, 07:08 PM
I like to have the housings soda blasted. Then you can decide whether to coat it. There’s a rattle can paint called “alumi-blast” which I think looks good. But you have to make sure everything is super clean. Aluma Blast is an Eastwood paint product. https://www.eastwood.com/search/?q=aluma%20blast this looks like a good idea, since i've tainted it in spots with the pool acid. |
bkrantz |
Dec 19 2022, 07:56 PM
914 Guru Group: Members Posts: 7,763 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
I had mine media-blasted, and then I painted the sections with a matte epoxy clear coat. It darkened the color just a bit.
914werke |
Dec 19 2022, 10:32 PM
"I got blisters on me fingers" Group: Members Posts: 10,059 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Im working one one right now....
After media blasting it showed all sorts of voids, holes sort of like it had been rotting? Ive done a few of them & this is a first for me. Looks like Ill need to fill it with allmetal & sand to get it back to acceptable. |
Lo-Fi Version | Time is now: 16th May 2024 - 07:03 AM |
