914 factory look exterior mirror sale |
dr914@autoatlanta.com |
Dec 19 2022, 11:53 AM
914 Guru Group: Members Posts: 7,856 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
SALE TODAY 24 HOURS ONLY - 914 EXTERIOR MIRROR R91473103910 NOW $150 INSTEAD OF $229.50 expires 12/20/2022 1pm
http://www.autoatlanta.com/Factory-Look-Po...1473103910.html comes with the gasket and the CORRECT screws |
Jim C |
Dec 19 2022, 12:10 PM
Member Group: Members Posts: 190 Joined: 11-July 19 From: Texas Member No.: 23,294 Region Association: Southwest Region |
SALE TODAY 24 HOURS ONLY - 914 EXTERIOR MIRROR R91473103910 NOW $150 INSTEAD OF $229.50 expires 12/20/2022 1pm http://www.autoatlanta.com/Factory-Look-Po...1473103910.html comes with the gasket and the CORRECT screws Is this early or late? I believe there was a difference wasn't there? |
DC_neun_vierzehn |
Dec 19 2022, 12:16 PM
Member Group: Members Posts: 378 Joined: 16-November 20 From: Delaware Shore Member No.: 24,893 Region Association: MidAtlantic Region |
Hi George. @dr914 @autoatlanta.com
I might just be me, but I find the info on the page confusing. Is this an OEM part? It says "factory look" in the title, but the description states "factory issue". |
DC_neun_vierzehn |
Dec 19 2022, 12:18 PM
It's a good deal either way!
I'm mostly wondering if I'm the only one who thinks OEM when I see "factory issue." |
Chris914n6 |
Dec 19 2022, 12:46 PM
Jackstands are my life. Group: Members Posts: 3,318 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
brushed chrome?
dhuckabay |
Dec 19 2022, 01:16 PM
Member Group: Members Posts: 222 Joined: 14-June 20 From: Idaho Member No.: 24,379 Region Association: Pacific Northwest |
Is this early or late? I believe there was a difference wasn't there? [/quote] It is a later model |
friethmiller |
Dec 19 2022, 02:04 PM
Member Group: Members Posts: 474 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
I have one of these. I found the quality of this mirror to be outstanding!
Dec 20 2022, 10:40 AM
the company that originally made them for Porsche makes them , but not in Germany any more. They are really identical to the originals but do not have the script on them
76-914 |
Dec 20 2022, 10:48 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
If they're the same as the ones that Sierra Madre offers then yes, they are very nice indeed!
mb911 |
Dec 20 2022, 10:59 AM
914 Guru Group: Members Posts: 6,850 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
That is such a good deal
Type 47 |
Dec 20 2022, 12:07 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
Is there a template/instructions for installing on the passenger door?
willieg |
Dec 20 2022, 12:11 PM
Member Group: Members Posts: 132 Joined: 13-August 18 From: Pleasant Hill Member No.: 22,389 Region Association: Northern California |
@type 47
There is a thread on 914World about the installation of a mirror on the passenger side. A finicky process but IMHO, well worth it. |
Type 47 |
Dec 20 2022, 10:08 PM
76-914 |
Dec 20 2022, 10:44 PM
@type 47 There is a thread on 914World about the installation of a mirror on the passenger side. A finicky process but IMHO, well worth it. Thanks. I suck at the search function. I always get 1500 posts I'd recommend that you pull the glass from the door to access. Once it's pulled drill through the existing nuts with a small 3/16" bit IIRC. Then from the outside use a 6mm bit to enlarge the hole to 6mm. This way you won't end up with a large oval hole because you weren't dead center. The mirror base would hide an enlarged hole but you'll always know it is there. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 15th May 2024 - 05:50 AM |
