QUOTE(Type 47 @ Dec 20 2022, 08:08 PM)
QUOTE(willieg @ Dec 20 2022, 10:11 AM)
@type 47
There is a thread on 914World about the installation of a mirror on the passenger side. A finicky process but IMHO, well worth it.
Thanks.
I suck at the search function. I always get 1500 posts
I'd recommend that you pull the glass from the door to access. Once it's pulled drill through the existing nuts with a small 3/16" bit IIRC. Then from the outside use a 6mm bit to enlarge the hole to 6mm. This way you won't end up with a large oval hole because you weren't dead center. The mirror base would hide an enlarged hole but you'll always know it is there.
