944 breaker, Are there any 944 parts common to 914s worth salvaging? |
BK911 |
Dec 28 2022, 12:52 PM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
bdstone914 |
Dec 28 2022, 12:58 PM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The 5 lug 944 front hubs (bearings, washers and locking nut) and rotors are 911 strut compatible (NOTE - may differ over model years). These items may be of value to anyone doing a 5 lug conversion. I think they even have "911" part numbers...? I have these on my GT tribute car, courtesy pick'n'pull (though I did replace the bearings with new ones), - Tony @'Retroracer The hubs are not 911 parts. The offset is about 1/2 inch less than a 911 hub and requires a spacer and longer studs installed to prevent the tires from rubbing. That may vary with the wheel offset. |
Retroracer |
Dec 28 2022, 02:26 PM
Senior Member Group: Members Posts: 614 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
The 5 lug 944 front hubs (bearings, washers and locking nut) and rotors are 911 strut compatible (NOTE - may differ over model years). These items may be of value to anyone doing a 5 lug conversion. I think they even have "911" part numbers...? I have these on my GT tribute car, courtesy pick'n'pull (though I did replace the bearings with new ones), - Tony @'Retroracer The hubs are not 911 parts. The offset is about 1/2 inch less than a 911 hub and requires a spacer and longer studs installed to prevent the tires from rubbing. That may vary with the wheel offset. @bdstone914 - I didn't claim they were "bolt on"; as stated, they are compatible with the 911 strut. Any GT (or flared 914 variant) will likely run with spacers / longer studs anyway. There are also various offsets / depths to 911 hubs I believe. The OP asked for parts worth salvaging for a 914 - I believe these parts may have value, - Tony |
bdstone914 |
Dec 28 2022, 03:16 PM
The 5 lug 944 front hubs (bearings, washers and locking nut) and rotors are 911 strut compatible (NOTE - may differ over model years). These items may be of value to anyone doing a 5 lug conversion. I think they even have "911" part numbers...? I have these on my GT tribute car, courtesy pick'n'pull (though I did replace the bearings with new ones), - Tony @'Retroracer The hubs are not 911 parts. The offset is about 1/2 inch less than a 911 hub and requires a spacer and longer studs installed to prevent the tires from rubbing. That may vary with the wheel offset. @bdstone914 - I didn't claim they were "bolt on"; as stated, they are compatible with the 911 strut. Any GT (or flared 914 variant) will likely run with spacers / longer studs anyway. There are also various offsets / depths to 911 hubs I believe. The OP asked for parts worth salvaging for a 914 - I believe these parts may have value, - Tony I agree. Also the thrust washers for the hubs are compatable with 911 hubs. I still have a bunch of the lock nuts as they are about $30 each new |
frostyf |
Jan 4 2023, 10:20 AM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
frostyf |
Jan 4 2023, 10:22 AM
moldygreg |
Jan 4 2023, 11:34 AM
Stay Golden Group: Members Posts: 135 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest |
IIRC, the rear trailing arms, especially the alloy Turbo ones, can be used for Type 1 disc brake conversions. If it were me and I was already there, I'd harvest whatever I could. 944 924 values are rising. I'm pretty sure the rear glass hatches are NLA and / or $$$$$. If it has even a "decent" dash, it's worth grabbing. I saw an early 944 NOS dash that was close to $2000. ^^^ Good one! 1985.5 on up dashes are no longer available and worth $$$. Early dashes are being remade by Porsche Classic again, but are costly. If it has Sport Seats, grab them regardless of condition. |
Van B |
Jan 4 2023, 07:25 PM
Senior Member Group: Members Posts: 1,610 Joined: 20-October 21 From: Maryland Member No.: 26,011 Region Association: None |
Aux air regulator is the same as the 1.8 L-jet part… but who knows if it works
BK911 |
Jan 4 2023, 07:59 PM
If the spare looks like this one I would be intetested. Hi there, there is a space saver like that. I'll see what they're asking for a spare wheel and let you know likely price. Its numbered 911 361 022 11. Im not sure what postage etc would be. Thanks but I think that's a standard steelie. |
frostyf |
Jan 6 2023, 11:52 AM
Was too late getting back and the car has gone, but the space saver wheel is still there. It is steel construction but has a strange tire with two valves.
Not sure what the yard will ask for it, or how much shipping would be, but could buy it if anyone is interested! Thanks but I think that's a standard steelie. [/quote] Attached image(s) |
Lo-Fi Version | Time is now: 29th May 2024 - 12:53 AM |
