Question: Which flywheel? |
bossboy302 |
Dec 31 2022, 10:32 AM
Member Group: Members Posts: 77 Joined: 13-December 21 From: NorCal Member No.: 26,158 Region Association: None |
Sorry to have to ask again-I'm old and forgetful...
Putting a 2.2 into a 914 with a side shift trans-which flywheel works best? Thanks...again |
brant |
Dec 31 2022, 11:25 AM
2.2 6 cylinder I assume
Get a 914/6 flywheel Or early 911 2.0 flywheel |
flyer86d |
Dec 31 2022, 02:10 PM
Member Group: Members Posts: 425 Joined: 12-January 11 From: Corea, Maine Member No.: 12,585 Region Association: North East States |
The 914-6 flywheel is stamped with the correct TDC and timing marks. I don’t think the 911 flywheel is. Either one will work but correct me if I’m wrong.
Charlie |
bossboy302 |
Dec 31 2022, 03:37 PM
brant |
Dec 31 2022, 03:57 PM
The 914-6 flywheel is stamped with the correct TDC and timing marks. I don’t think the 911 flywheel is. Either one will work but correct me if I’m wrong. Charlie Great info-thanks all. Yes, a 2.2 6-cyl. So nothing from 4-cyl, correct? Thank, HNY 4 cylinder crank has the wrong number of mounting bolts But clutches can interchange |
zoomCat |
Dec 31 2022, 05:08 PM
Member Group: Members Posts: 161 Joined: 13-August 04 From: Cincinnati, OH Member No.: 2,526 Region Association: None |
Looks like the same part number.
https://www.pelicanparts.com/More_Info/9011...amp;SVSVSI=P914 The 914-6 flywheel is stamped with the correct TDC and timing marks. I don’t think the 911 flywheel is. Either one will work but correct me if I’m wrong. Charlie |
mlindner |
Jan 1 2023, 06:18 AM
Senior Member Group: Members Posts: 1,520 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Yes, six bolt early 911 flywheel. thats what I have in my 2.2.. works great with standard clutch package. Best, Mark
Lo-Fi Version | Time is now: 16th May 2024 - 04:42 AM |
