LED early fog light bulbs |
Geezer914 |
Jan 11 2023, 06:51 AM
Geezer914 Group: Members Posts: 1,409 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
I picked these up on Amazon. Bar code number is 2xBA20D-100W-W. Go to the GENSSi web site and look up BA20D bulbs. These are H6 bulbs for Motor cycle head lights.
jim_hoyland |
Jan 11 2023, 06:56 AM
Get that VIN ? Group: Members Posts: 9,291 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
How do they fit ?
Geezer914 |
Jan 11 2023, 07:14 AM
They fit into the fog light socket as the base is the same as the original 35W bulb.
Freezin 914 |
Jan 11 2023, 07:23 AM
Senior Member Group: Members Posts: 856 Joined: 27-July 14 From: Wisconsin Member No.: 17,687 Region Association: Upper MidWest |
What is the Kelvin color?
eric9144 |
Jan 11 2023, 12:49 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
So the "D" in the bulb description is for dual filament aka, motorcycle headlight has high and low beam, that's why the original bulbs are "S" for single--did you have to bridge the connection to kick it into high beam mode or just letting it sit on low beam, or does it go into high beam mode naturally? (IMG:style_emoticons/default/confused24.gif)
Geezer914 |
Jan 11 2023, 02:26 PM
Just installed them. The LED's at 50w are going to be much brighter than the original 35w bulb.
Mikey914 |
Jan 12 2023, 12:32 PM
The rubber man Group: Members Posts: 12,661 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
That's weird. LED's shouldn't draw 100W. I'm guessing (and hoping for your sake) that the 100W is a marketing ploy to say they are equivalent to. If not you will have issues without a relay.
Geezer914 |
Jan 12 2023, 03:35 PM
They are not drawing 100W, the out put is equivalent to 100W.
Mikey914 |
Jan 12 2023, 05:05 PM
Sounds much better interested to see how these work.
Type 47 |
Jan 12 2023, 11:35 PM
Senior Member Group: Members Posts: 782 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None |
searunner |
Jan 13 2023, 05:20 AM
Newbie Group: Members Posts: 16 Joined: 8-January 20 From: italy Member No.: 23,809 Region Association: None |
I prefer to transform the FOG light to DAY Light to avoid the constant activations of the Headlight:
Adhesive low thicknesses LED light POWER unknown BUT effective works as DAY Light https://photos.app.goo.gl/ZPP79uJhnXw8KeCT6 connected to TAIL light - I have protected the LED lights with TWO Yellow HELLA glasses https://photos.app.goo.gl/KMg7JuxFKjW9J2v88 https://photos.app.goo.gl/goVW9edwwpvwywtu7 |
davep |
Jan 13 2023, 09:30 AM
914 Historian Group: Benefactors Posts: 5,141 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
So the "D" in the bulb description is for dual filament aka, motorcycle headlight has high and low beam, that's why the original bulbs are "S" for single--did you have to bridge the connection to kick it into high beam mode or just letting it sit on low beam, or does it go into high beam mode naturally? Despite being marked as D for dual, they are actually single so no switching is needed or possible. I guess the big question is how does the light pattern compare with the original filament bulb. The position in the housing and the reflector were designed for the filament to be in a particular position that the LED does not appear to duplicate. I would be interested in some sort of a comparison for the beam spread. |
MartyYeoman |
Jan 16 2023, 04:10 PM
Senior Member Group: Members Posts: 1,518 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
Lo-Fi Version | Time is now: 15th May 2024 - 01:59 AM |
