How do I Remove/install of Cylinder head temp sender, tight working space |
AzGuy238 |
Jan 12 2023, 02:57 PM
Newbie Group: Members Posts: 22 Joined: 26-July 20 From: Montgomery, TX Member No.: 24,536 Region Association: Southwest Region |
I recently purchased a Cyl head Temp sender extension from Brad Mauer....and a new sender. Working room is very tight in that area. I'm thinking of using a 13mm semi deep socket and maybe vice grips .....Has anyone got a better idea. Do I need to remove the Fuel Injection rails first? Thanks
brant |
Jan 12 2023, 03:09 PM
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Get a cheep 3 inch socket extension
Dremel off one of the 4 corners on the square drive end Make the cut a small valley that will be large enough to hold the sender wire Put the deep socket on Then install the extension while guiding the wire into the cut |
Geezer914 |
Jan 12 2023, 03:25 PM
Geezer914 Group: Members Posts: 1,394 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Spray the sensor with PB Blaster and let it sit over night. You have aluminum threads in an aluminum head. You don't want the sensor snapping off leaving the threads! Ask me how I know. I had to carefully drill and tap out the head and make an insert to fit the new sensor.
bzettner |
Jan 12 2023, 03:45 PM
Member Group: Members Posts: 211 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
My variation to the solution. I did not want to destroy one of my Snap On sockets (and didn't want to go buy a cheap one (IMG:style_emoticons/default/confused24.gif) ) This came with some HF mega set of driver "tips". Works great with a 1/4" socket to drive it. (IMG:style_emoticons/default/piratenanner.gif) |
Lockwodo |
Jan 12 2023, 03:49 PM
Member Group: Members Posts: 199 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
A related question: After the CHT sender is in place, is there a grommet or rubber plug that is supposed to close off the hole in the engine tin to prevent cooling air from escaping? My car is a '74 2.0.
brant |
Jan 12 2023, 04:18 PM
brant |
Jan 12 2023, 04:20 PM
My variation to the solution. I did not want to destroy one of my Snap On sockets (and didn't want to go buy a cheap one (IMG:style_emoticons/default/confused24.gif) ) This came with some HF mega set of driver "tips". Works great with a 1/4" socket to drive it. (IMG:style_emoticons/default/piratenanner.gif) thats a beauty! I bought an extension from the FLAPS for around 3 dollars... carry it in the car with spare senders on road trips. |
AzGuy238 |
Jan 13 2023, 08:02 AM
My variation to the solution. I did not want to destroy one of my Snap On sockets (and didn't want to go buy a cheap one (IMG:style_emoticons/default/confused24.gif) ) This came with some HF mega set of driver "tips". Works great with a 1/4" socket to drive it. (IMG:style_emoticons/default/piratenanner.gif) thats a beauty! I bought an extension from the FLAPS for around 3 dollars... carry it in the car with spare senders on road trips. Thanks everyone for your tips and suggestions. Wayne |
AzGuy238 |
Jan 29 2023, 11:54 AM
My variation to the solution. I did not want to destroy one of my Snap On sockets (and didn't want to go buy a cheap one (IMG:style_emoticons/default/confused24.gif) ) This came with some HF mega set of driver "tips". Works great with a 1/4" socket to drive it. (IMG:style_emoticons/default/piratenanner.gif) thats a beauty! I bought an extension from the FLAPS for around 3 dollars... carry it in the car with spare senders on road trips. Thanks everyone for your tips and suggestions. Wayne So to follow up: I followed the example provided by @bzettner and it worked great (btw, I used a "wobbly" 3" extension and it gave a little more room to work). OK, got the old sender out just fine....but how do you get the new one back in? For about two weeks of frustration and trying every possible tool I owned I was ready to start taking the engine out of the car! Then I happened to harken back to the old days when I had Sunbeam Tigers....and the way weird way I had to install the rear spark plugs thru a hole in the firewall under the dash....with a piece of gargen hose! Yes, Yes, a hose. So I took a scrap piece of about 1/2" to 5/8" Inside diameter heater hose...cut it to about 5" in length, pushed the sender into one end and VOILA! got it screwed in the first time. All is well again in my 914 World! |
AzGuy238 |
Jan 29 2023, 11:55 AM
Lo-Fi Version | Time is now: 9th May 2024 - 06:42 AM |
