How do I Remove/install of Cylinder head temp sender, tight working space |
AzGuy238 |
Jan 12 2023, 02:57 PM
Newbie Group: Members Posts: 22 Joined: 26-July 20 From: Montgomery, TX Member No.: 24,536 Region Association: Southwest Region |
I recently purchased a Cyl head Temp sender extension from Brad Mauer....and a new sender. Working room is very tight in that area. I'm thinking of using a 13mm semi deep socket and maybe vice grips .....Has anyone got a better idea. Do I need to remove the Fuel Injection rails first? Thanks
Geezer914 |
Jan 12 2023, 03:25 PM
Geezer914 Group: Members Posts: 1,421 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Spray the sensor with PB Blaster and let it sit over night. You have aluminum threads in an aluminum head. You don't want the sensor snapping off leaving the threads! Ask me how I know. I had to carefully drill and tap out the head and make an insert to fit the new sensor.
Lo-Fi Version | Time is now: 20th May 2024 - 02:30 AM |
