How do I Remove/install of Cylinder head temp sender, tight working space |
AzGuy238 |
Jan 12 2023, 02:57 PM
Newbie Group: Members Posts: 22 Joined: 26-July 20 From: Montgomery, TX Member No.: 24,536 Region Association: Southwest Region |
I recently purchased a Cyl head Temp sender extension from Brad Mauer....and a new sender. Working room is very tight in that area. I'm thinking of using a 13mm semi deep socket and maybe vice grips .....Has anyone got a better idea. Do I need to remove the Fuel Injection rails first? Thanks
bzettner |
Jan 12 2023, 03:45 PM
Member Group: Members Posts: 211 Joined: 2-June 13 From: San Antonio, TX Member No.: 15,951 Region Association: Southwest Region |
My variation to the solution. I did not want to destroy one of my Snap On sockets (and didn't want to go buy a cheap one (IMG:style_emoticons/default/confused24.gif) ) This came with some HF mega set of driver "tips". Works great with a 1/4" socket to drive it. (IMG:style_emoticons/default/piratenanner.gif) |
brant |
Jan 12 2023, 04:20 PM
914 Wizard Group: Members Posts: 11,625 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
My variation to the solution. I did not want to destroy one of my Snap On sockets (and didn't want to go buy a cheap one (IMG:style_emoticons/default/confused24.gif) ) This came with some HF mega set of driver "tips". Works great with a 1/4" socket to drive it. (IMG:style_emoticons/default/piratenanner.gif) thats a beauty! I bought an extension from the FLAPS for around 3 dollars... carry it in the car with spare senders on road trips. |
AzGuy238 |
Jan 13 2023, 08:02 AM
My variation to the solution. I did not want to destroy one of my Snap On sockets (and didn't want to go buy a cheap one (IMG:style_emoticons/default/confused24.gif) ) This came with some HF mega set of driver "tips". Works great with a 1/4" socket to drive it. (IMG:style_emoticons/default/piratenanner.gif) thats a beauty! I bought an extension from the FLAPS for around 3 dollars... carry it in the car with spare senders on road trips. Thanks everyone for your tips and suggestions. Wayne |
AzGuy238 |
Jan 29 2023, 11:54 AM
My variation to the solution. I did not want to destroy one of my Snap On sockets (and didn't want to go buy a cheap one (IMG:style_emoticons/default/confused24.gif) ) This came with some HF mega set of driver "tips". Works great with a 1/4" socket to drive it. (IMG:style_emoticons/default/piratenanner.gif) thats a beauty! I bought an extension from the FLAPS for around 3 dollars... carry it in the car with spare senders on road trips. Thanks everyone for your tips and suggestions. Wayne So to follow up: I followed the example provided by @bzettner and it worked great (btw, I used a "wobbly" 3" extension and it gave a little more room to work). OK, got the old sender out just fine....but how do you get the new one back in? For about two weeks of frustration and trying every possible tool I owned I was ready to start taking the engine out of the car! Then I happened to harken back to the old days when I had Sunbeam Tigers....and the way weird way I had to install the rear spark plugs thru a hole in the firewall under the dash....with a piece of gargen hose! Yes, Yes, a hose. So I took a scrap piece of about 1/2" to 5/8" Inside diameter heater hose...cut it to about 5" in length, pushed the sender into one end and VOILA! got it screwed in the first time. All is well again in my 914 World! |
AzGuy238 |
Jan 29 2023, 11:55 AM
Lo-Fi Version | Time is now: 20th May 2024 - 05:43 AM |
