WTB- complete front wire harness for a 75 |
yellowporky |
Jan 13 2023, 02:47 PM
Member Group: Members Posts: 422 Joined: 18-October 09 From: Martinez, Ca. Member No.: 10,948 Region Association: Northern California |
I am looking for an excellent condition 1975 front wire harness complete from fuse block
Please let me know what you have Thank you Chris |
914werke |
Jan 13 2023, 02:57 PM
"I got blisters on me fingers" Group: Members Posts: 10,029 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
There is no "front" "rear" "middle" wire harness.
The chassis wiring loom for our cars are 1 piece, from front to rear. |
yellowporky |
Jan 13 2023, 03:02 PM
Been a while since I dug into one of these but I thought there is a loom that goes through a larger grommet in the front behind the fuse panel.
Everything that goes forward is what I need. Mine got cut up during a moment of stupidity Maybe I should look again and repost Thanks |
yellowporky |
Jan 13 2023, 04:01 PM
So it looks like I need to find someone with a damaged harness who is willing to chop off the part that goes through the large grommet to the front trunk. I can use a plug where the grommet goes so I can splice it together as this is not a factory correct car.
Thank you all for your help Chris |
JamesJ |
Jan 13 2023, 04:54 PM
Member Group: Members Posts: 220 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California |
If another member here doesn't have one, try High Performance House in Redwood City.
JeffBowlsby |
Jan 13 2023, 07:51 PM
914 Wiring Harnesses Group: Members Posts: 8,485 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Chris you would be best off replacing the entire chassis harness because you will be chasing gremlins at some point with the multitude of splices needed at that stressed juncture.
Note to all, THERE IS NO NEED TO CUT WIRES! Each one easily disconnects if you need to move it for any reason. |
Jan 13 2023, 08:07 PM
914-6 GT in waiting Group: Members Posts: 19,245 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I have a later harnesses. I’m not sure what year it is but it’s in very good shape. I’ll take some pics and you can decide if it will work for you.
gereed75 |
Jan 13 2023, 10:44 PM
Senior Member Group: Members Posts: 1,241 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States |
I also have a late harness in decent shape that might work for you if Marks doesn’t work out but it will be awhile before I could get to it to take some pix. February sometime.
Lo-Fi Version | Time is now: 29th April 2024 - 03:37 PM |
