Steering play/slack |
ronan |
Jan 13 2023, 05:21 PM
Newbie Group: Members Posts: 13 Joined: 23-December 22 From: Phoenix Member No.: 27,051 Region Association: Central California |
I just took apart the steering wheel on my 75 1.8, because there is way too much play from side to side and top to bottom. The steering wheel moves about a half inch in any direction. As I took it apart I gathered what seem to be disintegrated parts of an old bearing, or something else, I don’t know, the image is attached. From what I could tell everything looked normal (I am a new 914 owner and new to old cars in general though, so I don’t really know what to look for.) Has anyone had this problem before? What is the disintegrated stuff?
Attached thumbnail(s) |
Puebloswatcop |
Jan 13 2023, 09:14 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Where exactly were you in the dis assembly process when you found this. It is possible that it's part of a bearing...but need to know where it was found.
ronan |
Jan 13 2023, 09:38 PM
Where exactly were you in the dis assembly process when you found this. It is possible that it's part of a bearing...but need to know where it was found. Found it after in the housing for the turn signals and ignition, in that chamber. There’s a bearing in there that all of this crud was sitting on. |
Lo-Fi Version | Time is now: 28th April 2024 - 08:07 PM |
